Go to Post Starting projects is fun, easy, and exposes you to new things, but finishing them shows true character. - Greg McKaskle [more]
Unread 20-04-2006, 10:43
Dillon Compton Dillon Compton is offline
Jack-Of-All-Trades
FRC #1391 (Metal Moose)
Dillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud of
Send a message via AIM to Dillon Compton
Re: pic: Omnitrack Summer Project?
Uhm...If the rollers are at 45 degree angles to the tread, then the tread should be mounted parallel to the frame at the four corners; the nature of mecanum systems is such that you receive standard weight distro, speed, and forward traction, while gaining the manuverability of omniwheel systems.
Good luck.
www.metalmoose.com
pic: 1541 - SARTANYAC: Beta Project bombadier337 Robot Showcase 2 22-02-2006 19:24
pic: Project X climbing up the side of the ramp CD47-Bot Robot Showcase 2 25-02-2004 23:24
SCRRF Robotics Summer Camps Redhead Jokes Southern California Regional Robotics Forum 0 24-03-2003 15:06
Preseason project AdamT General Forum 4 09-09-2002 00:52
MS Project Build Schedule joe_balint Technical Discussion 1 07-01-2002 03:25
