Go to Post How well does peanut butter transmit heat? - Lil' Lavery [more]
Unread 23-04-2006, 15:49
in between teams
AKA: Luke Van Oort
Re: pic: Crab Drive
Looking at this makes me think that it would be easy to make a ball-bearing shifter and build that into a swerve module. Now, that'd be awesome. I agree with RogerR on the rod placement, and I'll add that you might want to consider moving the wheel down some, it looks like it brings the module too close to the ground. You have to remember that the wheel material will compress a bit with the robot's weight on it and wear down a bit.
Team 1219: 2009 - Mentor
Direct Drive Four Motor System Collin Fultz Technical Discussion 42 02-11-2006 12:03
Crab drive question Tazlikesrobots Technical Discussion 13 31-07-2005 20:51
Controls for a Crab Drive Ein Control System 22 26-01-2005 20:31
rotation of body of crab drive robots michael_obrien Technical Discussion 6 22-10-2003 19:32
how does crab drive work? Soukup Technical Discussion 13 25-04-2003 11:31
