Re: paper: FIRSTXMLdb beta
almost forgot, in order to use java from the command prompt (for .class files) you need to set the Path variable. Funny how you take these things for granted after a semester of Java.
OK here is how you set the Path variable in Windows. 1: Open My Computer 2: Open the folder "C rogram FilesJava"3: Open your latest (highest version number) jre folder (mine is "jre1.5.0_04") 4: Open the bin folder 5: Highlight and copy (ctrl-c) the address of this folder (mine is "C rogram FilesJavajre1.5.0_04bin")6: Open Control Panel (Start->Control Panel or Start->Settings->Control Panel) 7: Open the System icon (Performance and Maintenance->System if you are in category view) 8: Click on the Advanced Tab 9: Click on the Environment Variables Button 10: Under the "System Variables" double click on the "Path" Variable 11: Use the right arrow key to move to the end of the string in the "Variable Value:" field 12: Type a semicolon ';' then a space, then paste the bin folder address (For me it would be "; C rogram FilesJavajre1.5.0_04bin")13: Click OK buttons till you get back to Control Panel (3 OKs). 14: Restart Command Prompt if you are currently running it 15: Now you can run java programs like this: C:\FIRSTXMLdb Beta>java ScoutTeams 365 1495 And thats it, See you in Atlanta! |
| Man uses a paper clip to barter for house - Story on USAToday | Ken Leung | Chit-Chat | 4 | 26-07-2006 22:01 |
| Robots doing origami! | RoboMom | Math and Science | 4 | 24-10-2004 19:42 |
| Some code in C that we may need if we are in trouble | Andrew Rudolph | Chit-Chat | 16 | 07-10-2003 21:34 |
| Impending BASIC Stamp Editor Beta 2 release | Greg Ross | Programming | 9 | 19-09-2003 06:05 |
| White Paper Discuss: HeatWave 2003 Handheld DB (Beta Version) | CD47-Bot | Extra Discussion | 4 | 07-03-2003 20:22 |
