Go to Post I <3 statistics. - Barry Bonzack [more]
Unread 23-05-2006, 13:19
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Re: pic: AndyMark Mecanums
Have you all seen the vehicles that AIRTRAX is making holonomic?
I was amazed that they figured out how to do holonomic drive for forklifts and scissor lifts.
Just something that caught my interest.
-Q
Electrical Engineer Illini
Unread 23-05-2006, 14:45
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Originally Posted by ahecht
...unless you want to thumpthumpthump down the field, I hope the final rollers are a bit rounder than that.
With enough weight on the wheels, the TechnoKats' prototype mecanum drive base is very smooth. The installed rollers are sufficiently "squishy" that they don't do a lot of thumping to begin with, and they also wore down a bit to a slightly rounder profile after driving on concrete for a while.
Unread 23-05-2006, 16:42
artdutra04's Avatar
VEX Robotics Engineer
Originally Posted by Qbranch
OK here's something that has bugged me for years.
can someone verify that:
1. The wheels for holonomic drive are called "Mecanum" wheels.
2. The drive system itself is called "holonomic drive"
3. The drive system is not called "Mecanum drive"
PM me or just reply here. Thanks.
-Q
See these pictures for examples of holonomic and mecanum drive robots.
Art Dutra IV
世上无难事,只怕有心人.
Unread 23-05-2006, 17:55
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Wikipedia actually has a pretty good definition of holonomic as the term applies to robots:
Originally Posted by Wikipedia
In robotics holonomicity refers to the relationship between the controllable and total degrees of freedom of a given robot (or part thereof). If the controllable degrees of freedom is equal to the total degrees of freedom then the robot is said to be holonomic.
So a robot drivetrain that is truly holonomic as defined above would have three degrees of freedom; i.e., three independently controllable wheels not directed along the same axis. A robot drivetrain with four omniwheels arranged on the corners is actually redundant, but with relatively simple math can be made to function like one that is holonomic. The same statement applies to a robot drivetrain with four mecanum wheels.
Richard Wallace
since 2003
Unread 23-05-2006, 18:17
Simon Strauss's Avatar
Simon Strauss Simon Strauss is offline
None #1155 (Sciborgs)
Simon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant future
Send a message via AIM to Simon Strauss
Aka Kiwi drive which is usually categorized with the Holonomic drive Art had above due to their usage of the same type of wheel
NYC Chairmen's Award Winners 2007 Thank you team 2265, you were our project and we couldnt have done it without you all
New Jersey Regional Finalists thanks to teams 359 and 486 Aloha
"Beware of the Ska Robot Army!" -The Aquabats
Unread 23-05-2006, 18:52
EricH EricH is offline
Originally Posted by bigboi146
I dont get them. Can you use them in an omni drive. they look awsome though.
See the explanations above. A "mecanum" drivetrain is set up like a four wheel drive with each wheel independently powered. You cannot have two wheels powered by the same motor/tranny. If you do, you will lose all sideways ability, and you may as well go with four wheel drive. There are three teams that I know about that have used this setup in competition. Note: If you tried to use them in a "standard" omni drive (Art's left-hand pic), you would go nowhere, or possibly spin out or fry a motor or something else equally bad. (Actually, mecanum drive is a subset of omni drive.)
Unread 23-05-2006, 19:22
RogerR's Avatar
RogerR RogerR is online now
AKA: Roger Riquelme
FRC #3844 (Wildbots)
actually, in a four wheel omni-drive, if you paired the wheels across from each other together and attached them to a motor, you'd be able to translate freely. unfortunately, this'd mean you would be unable to rotate. i believe you could achieve similar results by pairing the the diagonal wheels on a mecanum drive train together.
"But to say that the race is a metaphor for life is to miss the point. The race is everything. It obliterates whatever isn't racing. Life is a metaphor for the race." -- Donald Antrim
Unread 23-05-2006, 19:41
Now that I think about it, yes you could, in theory. Again, you could not turn the robot. Also, it might be a bit difficult to link a wheel on the left front corner with the one on the right back corner...
Unread 23-05-2006, 19:45
there are ways, such as elaborate rotating shafts or using tapered gears to angle them the needed degrees then run those together with chain and sprocket with a motor and tranny in the center, would be heavy though.
Unread 23-05-2006, 22:36
ahecht's Avatar
ahecht ahecht is offline
'Luzer'
AKA: Zan
ahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond repute
Send a message via ICQ to ahecht Send a message via AIM to ahecht Send a message via Yahoo to ahecht
Originally Posted by Billfred
I saw them in Atlanta, and they felt pretty solid to me (at least for prototypes). I've seen a lot of things made from 1/8" aluminum, and it seems to hold up to plenty of abuse, especially once you start putting some bends in there.
When 190 made our mecanum wheel, we originally had our rollers supported by 1/8" aluminum tabs, but we found that lose quickly bent when supporting a 130 pound robot making rapid movements. We switched to 1/8" steel, and while those were much better, we still had the occasional bent tab.
Zan Hecht
Scorekeeper: '05 Championship DaVinci Field/'10 WPI Regional
Co-Founder: WPI-EBOT Educational Robotics Program
Alumnus: WPI/Mass Academy Team #190
Alumnus (and founder): Oakwood Robotics Team #992
"Life is an odd numbered problem the answer isn't in the back of the book." — Anonymous WPI Student
Unread 24-05-2006, 16:50
And mecanums are heavy enough as it is. We can make some pretty light ones if we want to, but they still weigh at least as much as our six-wheel drive. (if you include trannies on both systems)
Unread 18-08-2006, 16:13
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Hey Andy,
Is there any chance you could share some general dimensions for these wheels so that those of us who're considering ordering a set can start to work them into our plans? Unless I've missed it elsewhere, it'd be fantastic to know as little as overall diameter and thickness, but if you've got more than that, I'll take it.
--Madison--
...down at the Ozdust!
Unread 17-09-2006, 22:54
WernerNYK WernerNYK is offline
AKA: Chris Werner
FRC #0190 (Gompei & the HERD)
WernerNYK is a jewel in the roughWernerNYK is a jewel in the roughWernerNYK is a jewel in the rough
Send a message via AIM to WernerNYK
-Q
1. Mecanum refers to the name of the compnay which the original creator worked for at the time of his invention (or at least to the person whose name is on the patent of the design which is most commonly mimiced by FIRST teams). Bengt Ilon developed this design, if my memory serves me correctly in the mid-1970s.
2. A holonomic platform, most literally is defined as one which has the ability to instantaneously move in any given direction (on a given plane). It does not need to be accomplished with mecanum wheels, and may not necessarily require wheels at all (I'm thinking "bumper boats" right off the top of my head - although not as controllable, these do fit the general terms).
3. There is technically no such thing as a Mecanum drive, although within the FIRST community, a holonomic drive platform using Mecanum-style wheels has become known as a Mecanum drive platform.
I realize this is a few months down the line, but hope it clarifies some things for you -- sorry in advance if any of my "facts" or a bit off, I'm replying to this based solely on memory of research I did almost two years ago.
EDIT: His name was not Ilon Mecanum -- Mecanum was the company he worked for. Ooops.
-Chris Werner
"Production Manager"
BattleCry@WPI
Team 190 - WPI & Mass Academy
Est. 1992!
Team 871 - Former team leader
Unread 17-09-2006, 23:18
Dan Petrovic's Avatar
FRC #0166 (Chop Shop)
Originally Posted by WernerNYK
1. Mecanum refers to the original creator (or at least to the person whose name is on the patent of the design which is most commonly mimiced by FIRST teams). Ilan Mecanum developed this design, if my memory serves me correctly in the mid-1970s.
The guy who invented Mecanum wheels was Bengt Ilon. I have no idea how they got the name Mecanum. They can be also called Ilon wheels.
This is all according to Wikipedia... and as we all know "I SAW IT ON THE INTERNET IT MUST BE TRUE!"
Unread 17-09-2006, 23:25
AKA: Chris Werner
Ah yes, now I remember. You're right.. I retract my prior statement, and say that the company he worked for was "Mecanum something or other"
-Chris Werner
BattleCry@WPI
Est. 1992!
Pic: Easy to make mecanums.. Tatsu Technical Discussion 31 08-11-2006 15:25
Andymark.biz Andy Baker Technical Discussion 119 01-05-2006 23:30
pic: 25-match-old andymark treads Bongle Extra Discussion 3 02-04-2006 01:07
mounting andymark wheels VEN Technical Discussion 10 04-02-2006 00:14
pic: Reworked AndyMark Gearbox Mark Jones Robot Showcase 17 07-12-2005 22:53
