| View Poll Results: What size wheels? | |||
| < 4" |
3 | 3.30% |
| 4" |
13 | 14.29% |
| 5" |
9 | 9.89% |
| 6" |
32 | 35.16% |
| 8" |
28 | 30.77% |
| 10" |
2 | 2.20% |
| 12" |
4 | 4.40% |
| Voters: 91. You may not vote on this poll | |||
Re: Wheel size poll
Four 6" custom aluminum wheels with Nitrile tread, 3/4" width. Check them out.
Last year custom wheels with conveyor belt tread ruled the field. This year cheaper, simpler IFI and AM wheels ruled the field with their extremely wide tread (1" and over). This year 604 got pushed around because so many people had these wheels. Darn IFI and AndyMark for making quality products! ![]() |
Re: Wheel size poll
Where do you guys get wheels that are easy to machine out like in the post above. I'm looking for some plain 4" wheels that i can machine out some of it and im not having any luck. Any rocomendations or anything to search for? Thanks.
Sorry A little off topic there, but this year my team used 6" AM omnis and 6"/1.5" Ifi's. |
Re: Wheel size poll
6x 8" Skyway non-pneumatic wheels (KOP) ground flat with SBR Roughtop inclined conveyor belting from McMaster-Carr on them, attached with small wood screws. We ended up using ginormous 54-tooth AndyMark aluminum sprockets on them. Next year, I'd really like to downsize to 6", (Somewhere I have math that backs up what Jeff said about those being a sweet spot, at least in terms of gearing) although one of the mentors wants bigger wheels. (I really have no clue why)
Re: Wheel size poll
We used 6" Skyway wheels from the Kit, turned down to 5.75", in a 6WD arrangement with custom-built omniwheels at the corners. This was all attached to the standard kitbot gearing of 17:1 and performed respectably. I wouldn't hesitate to use the setup again.
| 2006 game poll #1 (field size) | dhitchco | Rumor Mill | 18 | 30-12-2005 23:31 |
| pic: Chantilly Academy's 4 Wheel Drive 4 Wheel Steering!!!! | jskene | Robot Showcase | 25 | 18-02-2005 20:24 |
| 3 part wheel poll | Zippiot | Robot Showcase | 2 | 11-02-2005 21:16 |
| Calculating Wheel Size | phrontist | Technical Discussion | 15 | 07-09-2004 18:55 |
| Calculating Wheel Size To Climb | Yan Wang | Math and Science | 12 | 18-01-2004 22:49 |
