Re: pic: vex omni drive
Nice demonstration!
Someone posted another VEX holonomic drive a few months ago. You may want to compare notes. |
Do you have this coded for 3d movement (translation + rotation)? It looks like you are just playing around with each motor to make it move back and forth.
If you want, I can send you the drive code for my kiwi bot: http://www.team195.com/files/kiwi.wmv |
yeah i was just using the drive code that comes with the kit. that would be great if i coould see your code also any suggestions on what i could add to the tower on it. the ratio on the lower bar is 10:1 from the motor Last edited by 1902_Battery_SGT : 27-05-2006 at 13:33. |
did you use my 1st frame design or do great minds think alike
well my vector were a mess so i did a redesign 1st http://www.chiefdelphi.com/media/photos/24501 redesign http://www.chiefdelphi.com/media/photos/24505 |
yes i "borrowed" your ideah |
| pic: it's a Vex Holonomic Drive! | artdutra04 | Robot Showcase | 29 | 01-11-2006 23:08 |
| pic: simple omni vex bot | colin340 | FIRST Tech Challenge | 15 | 05-05-2006 17:16 |
| omni drive vs tank | |20807 61|2|_ | Technical Discussion | 49 | 17-01-2006 13:54 |
| Omni-drive autonomous questions | Andrew Schuetze | Programming | 6 | 17-01-2006 12:15 |
| pic: Omni Wheel Drive -- Top | Richard Wallace | Extra Discussion | 4 | 05-12-2005 18:55 |
