Go to Post Physical items will be lost along the way eventually but memories will never be forgotten. - Connor McBride [more]
Go Back   Chief Delphi > Other > FIRST Tech Challenge
Unread 27-05-2006, 10:10
1902_Battery_SGT's Avatar
1902_Battery_SGT 1902_Battery_SGT is offline
100% charged 100% of the time
AKA: Scott
FRC #1902 (Exploding Bacon)
1902_Battery_SGT is a name known to all1902_Battery_SGT is a name known to all1902_Battery_SGT is a name known to all1902_Battery_SGT is a name known to all1902_Battery_SGT is a name known to all1902_Battery_SGT is a name known to all
Send a message via AIM to 1902_Battery_SGT
Re: pic: vex omni drive
Originally Posted by Tom Bottiglieri
Do you have this coded for 3d movement (translation + rotation)? It looks like you are just playing around with each motor to make it move back and forth.
If you want, I can send you the drive code for my kiwi bot: http://www.team195.com/files/kiwi.wmv
yeah i was just using the drive code that comes with the kit. that would be great if i coould see your code
also any suggestions on what i could add to the tower on it. the ratio on the lower bar is 10:1 from the motor
Unread 28-05-2006, 17:18
colin340 colin340 is offline
human
AKA: Colin Nobles
FRC #0148
colin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond repute
did you use my 1st frame design or do great minds think alike
well my vector were a mess so i did a redesign
1st http://www.chiefdelphi.com/media/photos/24501
redesign http://www.chiefdelphi.com/media/photos/24505
61 77 77 20 77 69 74 74 6c 65 20 62 61 62 79 20 63 6f 6e 64 6f 72 20 69 73 20 72 65 61 64 69 6e 67 20 43 44
Unread 28-05-2006, 17:55
AKA: Scott
yes i "borrowed" your ideah
pic: it's a Vex Holonomic Drive! artdutra04 Robot Showcase 29 01-11-2006 23:08
pic: simple omni vex bot colin340 FIRST Tech Challenge 15 05-05-2006 17:16
omni drive vs tank |20807 61|2|_ Technical Discussion 49 17-01-2006 13:54
Omni-drive autonomous questions Andrew Schuetze Programming 6 17-01-2006 12:15
pic: Omni Wheel Drive -- Top Richard Wallace Extra Discussion 4 05-12-2005 18:55
