Go to Post I'd love to see a simple, robust system that connects quickly and dependably. - Andy Baker [more]
Unread 02-06-2006, 08:18
patrickrd's Avatar
patrickrd patrickrd is offline
AKA: Patrick Dingle
patrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to behold
Send a message via AIM to patrickrd
Re: pic: Helical Gears?
This picture is disturbing. How does it look like perfect continuous diagonal lines on both the pinion gear and the driven gear, and normal spur elsewhere? My best guess is that these are normal spurs with a little groove in the middle of each tooth... I have seen that before but I still can't see it looking like perfect diagonals in the picture.
If you look closely, you can also see that if we did assume they are helical gears, then the helix angles of the two gears would not mesh! One of the gears would need the angles reversed from what is shown.
Systems Engineer - Kiva Systems, Woburn MA
Alumni, Former Mechanical Team Leader - Cornell University Robocup - 1999, 2000, 2002, 2003 World Champions
Founder - Team 639 - Ithaca High School / Cornell University
Alumni - Team 190 - Mass Academy / WPI
Helical Gears in Inventor 8 xxmaddjxx Inventor 4 26-06-2004 00:04
helical gears Max Lobovsky Technical Discussion 10 16-04-2004 22:48
Helical Gears Gear Ratio Joe P Technical Discussion 11 23-01-2003 22:55
helical gears efficency Andrew Dahl Technical Discussion 0 07-01-2003 13:02
