Go to Post I am a FIRST addict. But I'm also sensible. - Rion Atkinson [more]
Unread 02-06-2006, 10:56
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: pic: Helical Gears?
It's an image artifact. The spacing of the gear teeth in the image is close to the size of the pixels, and the JPEG compression picks up on the diagonal aliasing and enhances it. Look at the bright area on the left end of the CIM motor and you'll see the same kind of illusion.
Helical Gears in Inventor 8 xxmaddjxx Inventor 4 26-06-2004 00:04
helical gears Max Lobovsky Technical Discussion 10 16-04-2004 22:48
Helical Gears Gear Ratio Joe P Technical Discussion 11 23-01-2003 22:55
helical gears efficency Andrew Dahl Technical Discussion 0 07-01-2003 13:02
