Go to Post I'll toss this out to stir up the pot: if you need double precision floats for your FRC software, you should re-think what you're doing. - Ether [more]
Unread 14-06-2006, 13:59
Joe Troy's Avatar
Joe Troy Joe Troy is offline
Survivor
FRC #0357 (Royal Assault)
Joe Troy has much to be proud ofJoe Troy has much to be proud ofJoe Troy has much to be proud ofJoe Troy has much to be proud ofJoe Troy has much to be proud ofJoe Troy has much to be proud ofJoe Troy has much to be proud ofJoe Troy has much to be proud ofJoe Troy has much to be proud ofJoe Troy has much to be proud of
Send a message via AIM to Joe Troy
Re: pic: Team 357's 2006 MIT InvenTeam
Originally Posted by sanddrag
Looks like a right angle drive on the motors. Are they worm gear drives or bevel gear drives? Are they stock off the shelf wheelchair motors? What size/quantity of batteries do you have? With 4 motors how is battery life?
The motors are equipped with right angle drives...the gear boxes have helical gear sets. The motors are a standard 24v wheelchair motor. We are using two 12v SLAs to provide the 24 volts required by the motors. Battery life is surprisingly good for a four wheel drive wheelchair.
We are currently at MIT as part of a two day exhibition by the Lemelson MIT InvenTeams. When we return from MIT we will be posting pictures, video and detailed specs for the Jester drive wheelchair.
FRC Team 357, UDHS Robotics & Engineering
VEX Team 357, UDHS JV Robotics & Engineering
FRC Host Site, Local Kickoff - Upper Darby HS, Drexel Hill, PA
FRC MAR District, Week 5 Event - Upper Darby HS, Drexel Hill, PA
Team 357's WheelChair Freddy Schurr General Forum 7 13-06-2006 10:04
Team 357's Website Knippschild Website Design/Showcase 5 18-03-2006 17:07
Team 357's Animation: Engineering New Frontiers mikexstudios 3D Animation and Competition 0 29-02-2004 10:37
MIT Team??? MadscientistGrl General Forum 4 18-09-2003 01:01
Team 357's Animation Quain 3D Animation and Competition 6 20-04-2002 14:19
