Go to Post FIRSTies always get Two Xmases! - [more]
Unread 17-06-2006, 01:44
Veselin Kolev's Avatar
Veselin Kolev Veselin Kolev is offline
X51 Production Company PGM (TM)
Veselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond repute
Re: pic: 1662's test tranny 5
MY team did this style shifter once. We were running it on an arm, so the torque was a lot higher. We used .375" diameter pins, which were just in a drilled .375" hole with retaining compound. The holes we had them mesh with were on the same size circle pattern, but 1/16" bigger. The shaft it ran on was a .625" keyed shaft. We just ran the power and the sliding through the keyway, it put up fine with it. Meshed very nicely, never had any problems. This was however, a low speed, high torque gearbox. Keep that in mind. Also keep in mind that this was a quick modification made in a day on a drill press and mill. Otherwise, these are a lot easier to make than a real dog-shifter. No cnc. A very ghetto solution when we used it, but it can be made very nicely into a drive train.
pic: 1662 test tranny M4 Sherman Extra Discussion 3 23-05-2006 18:02
pic: NJ- How to test the shooter. Rich Wong Extra Discussion 6 07-03-2006 11:36
First Complete Systems Test Pic Rob Robot Showcase 2 17-02-2006 13:57
pic: Dual FP KOP Tranny Andy Brockway Robot Showcase 5 06-02-2006 11:41
pic: Team 1501 Tranny Wayne Doenges Robot Showcase 8 19-02-2005 02:52
