Go to Post you should be putting forth you best effort every time you enter the field. - Protronie [more]
Unread 18-06-2006, 23:37
Joe J.'s Avatar
Joe J. Joe J. is offline
My Gaming Is FIRST!
AKA: Joey
Joe J. has a reputation beyond reputeJoe J. has a reputation beyond reputeJoe J. has a reputation beyond reputeJoe J. has a reputation beyond reputeJoe J. has a reputation beyond reputeJoe J. has a reputation beyond reputeJoe J. has a reputation beyond reputeJoe J. has a reputation beyond reputeJoe J. has a reputation beyond reputeJoe J. has a reputation beyond reputeJoe J. has a reputation beyond repute
Send a message via AIM to Joe J.
Re: pic: 862 Robot Parade
Originally Posted by Pat A.
Did you have any tire/wheel problems?
No real problems, but it does wear down the tires faster.
Originally Posted by Rohan_DHS
that's pretty cool. when u say they ran under their own power, do u mean off the batteries in the kit??
Our 2005 & 2006 robots were run off the KOP batteries. The 2006 bot went through 3 batteries (including shooting balls) the 2005 bot only need two batteries. The 2002 robot/personal transport was using a different battery.
Joe Jagadics
Lead Mentor / Coach
Lightning Robotics FRC Team 862
Unread 19-06-2006, 14:57
Not2B's Avatar
Not2B Not2B is offline
AKA: Brian Graham
Not2B has a reputation beyond reputeNot2B has a reputation beyond reputeNot2B has a reputation beyond reputeNot2B has a reputation beyond reputeNot2B has a reputation beyond reputeNot2B has a reputation beyond reputeNot2B has a reputation beyond reputeNot2B has a reputation beyond reputeNot2B has a reputation beyond reputeNot2B has a reputation beyond reputeNot2B has a reputation beyond repute
The 2002 robot/personal transport used a small yard tractor battery - it was about 35 amp/hour, and never dipped below 12.2 volts. Over a mile with 1 derek of weight, and the battery size wasn't THAT much bigger than the KOP battery.
The motors were very hot at the end... but it was like 90 degrees F also.
The wheel chair wheels looked OK. The IRI wheel treads were looking a little smooth by the end of the parade.
We were shooting balls the entire time with the 2006 bot, and doing some spins and fancy driving with the 2005 robot.
Lots of people saw derek go by on the personal transport/2002 bot, and yelled out "you made that?" to which the students would say "Yeah... and those 2 back there!" at which point jaws would drop.
Then we would throw candy at them.
Brian Graham
Robot parade in NYC the weekend before Atlanta Elgin Clock General Forum 1 07-04-2006 07:15
pic: 862 Teaser 3.... Joe J. Robot Showcase 4 11-02-2006 18:16
pic: 862 Teaser 2 Joe J. Robot Showcase 10 11-02-2006 00:51
**FIRST EMAIL**/Robot Parade at 2004 Championship Event! Damian Manda FIRST E-Mail Blast Archive 0 10-03-2004 17:47
Image Discuss: 862 -- Robot CD47-Bot Robot Showcase 1 19-02-2003 09:50
