Re: pic: Concentric Shifting Transmission Concept
That's a neat idea, and actually rather similar to the ball-lock trannies that started showing up a few years ago.
Example here The main difference obviously being your use spring loaded pins. While the pins would probably cary more torque, I'd be worried that the would bind and wouldn't release when you wanted them to. You could solve that with a tapered hole and tapered pin such that the pin would get forced downwards without something pushing it up from underneath, though. Which would basically make it like the ball-lock trannies. |
| Need shifting transmission layouts/ideas | sanddrag | Technical Discussion | 6 | 13-01-2006 13:24 |
| Is a shifting transmission really necessary? | Jay TenBrink | Technical Discussion | 78 | 02-08-2005 09:21 |
| pic: 222 2005 ball bearing style shifting transmission | team222badbrad | Robot Showcase | 2 | 11-03-2005 14:17 |
| Shifting Transmission | rmmlg | Technical Discussion | 5 | 25-12-2004 00:05 |
| 3 shifting transmission... | Arefin Bari | Technical Discussion | 19 | 04-03-2004 01:24 |
