Go to Post So many possibilities so many different meanings and soo many different opinions. LOL but i guess this is what FIRST is all about. - Bcahn836 [more]
Unread 19-06-2006, 23:21
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Re: pic: Concentric Shifting Transmission Concept
Maddie,
Interesting concept. First thing that came to mind was that the ends of the springs meant to keep the pins in place, are actually moving around the shaft for the gear that is not engaged, correct? Assuming that the pink is the input drive shaft. There will be some significant centrifical force driving the pins to the outside, so the springs need to be pretty strong and the ends need to be protected from the abrasion as they pass over each of the holes and pins. I remember seeing a segmented collar that had a spring wrapped around it that might be better. Sort of like the shoes on a centrifical clutch. A little lubricant and you should be good to go.
Al
WB9UVJ
www.wildstang.org
________________________
Need shifting transmission layouts/ideas sanddrag Technical Discussion 6 13-01-2006 13:24
Is a shifting transmission really necessary? Jay TenBrink Technical Discussion 78 02-08-2005 09:21
pic: 222 2005 ball bearing style shifting transmission team222badbrad Robot Showcase 2 11-03-2005 14:17
Shifting Transmission rmmlg Technical Discussion 5 25-12-2004 00:05
3 shifting transmission... Arefin Bari Technical Discussion 19 04-03-2004 01:24
