Go to Post When more STEM teams exist outside schools than in them, that will be one indication that a true cultural change has occurred. - gblake [more]
Unread 20-06-2006, 01:37
Gabe's Avatar
Gabe Gabe is offline
Pocket Full of Tools
FRC #0604 (Quixilver)
Gabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond repute
Re: pic: Concentric Shifting Transmission Concept
The solution could be to have not one, but two pins per spring. When you use one pin to lock you are essentially putting a shearing force on the pins. The problem arises when the pins retract and, as the pins wear down, they retract too far and shearing forces are applied to the springs which will damage them. By adding a very short pin segment with rounded ends in between the locking pin and the spring (shortened a bit), the transmission will unlock by splitting at the union between the pins. This concept is the same as the pin tumbler lock.
Notice that the ends of the pins are rounded to make the pins separate easily. When the lock is "locked", the inner cylinder can't turn because the pins aren't shearing. Study the image and apply the mechanism design to the shifting transmission. The simplest solution to the current design on the drawing board is to insert a ball bearing in between the locking pins and the springs, after having rounded over the end of the pin.
Team site: Q U I X I L V E R
My favorite tool is my imagination; I’m always finding new ways to use it.
Need shifting transmission layouts/ideas sanddrag Technical Discussion 6 13-01-2006 13:24
Is a shifting transmission really necessary? Jay TenBrink Technical Discussion 78 02-08-2005 09:21
pic: 222 2005 ball bearing style shifting transmission team222badbrad Robot Showcase 2 11-03-2005 14:17
Shifting Transmission rmmlg Technical Discussion 5 25-12-2004 00:05
3 shifting transmission... Arefin Bari Technical Discussion 19 04-03-2004 01:24
