Go to Post "There are two ways to compete in this world, you can drag your competitors down, or you can rise above them. Which is better for the world in the long run?" - Karthik [more]
Unread 07-05-2006, 09:35 PM
Andrew Schuetze's Avatar
Andrew Schuetze Andrew Schuetze is offline
499 Founder / Alamo FTC & FLL AP
Andrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond repute
Thumbs up Re: pic: Swerve!
Nice design as it used KOP items and simple framing materials. My only suggestion, considering that our team has no swerve experience but is working a summer proto-type, is that you consider the following.
I would prefer using a window motor with it's worm gear transmission to hold the steering position verses the Globe and it's back-drivable planetary gear system. Maybe this is not an issue and it is a waste of the window motor which could be needed for an arm or other manipulator. I do like the ability to steer two modules together. This too is something we are considering. Adds a few more options than having all four steered together and I don't know how one steers all four seperately without using a half of the KOP motor inventory for just the drive-train.
APS
Founder FRC 499
Parent alumni FRC 2745 & 4219
Co-Coach FTC 4549 & 6407
Alamo FTC Affiliate Partner
Alamo FLL Affiliate Partner
pic: Vex Swerve v3 JVN Extra Discussion 22 09-08-2006 05:28 PM
pic: Swerve Assembly CD47-Bot Extra Discussion 3 01-23-2004 08:02 PM
pic: Swerve^2 Prototype CD47-Bot Robot Showcase 24 01-23-2004 12:11 PM
pic: Lego Swerve Drive CD47-Bot Robot Showcase 14 06-26-2003 04:19 PM
