Go to Post You do need help. Don't reject offers of assistance from veterans. There are more things you don't know than you think there are. - Alan Anderson [more]
Unread 07-05-2006, 10:20 PM
NoodleKnight's Avatar
NoodleKnight NoodleKnight is offline
24 Hours of LeMons?
FRC #0100 (WHS&CHS Robotics)
NoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud of
Send a message via AIM to NoodleKnight
Re: pic: Swerve!
The window motor is back drivable, it's just extremely difficult and you'll more than likely break something in the process. Also some of the window motors are known to have a significant amount of back lash (although there was a trick with using keystock to solve this problem).
Also, take into consideration, how much force does it take to back drive the wheels? When will you be encountering this force? The modules are shielded on all sides and if another robot is sticking its manipulator into those modules to try and move them then they're going to encounter a penalty. I'm not saying using the window motors is a bad idea, I've seen teams use them instead of the globes; but same vice-versa, many teams use the globes to steer their swerve modules and have had no problems with back-driving -- since both motors seem to get the job done, I think that whether they are backdrivable or not shouldn't be the determining factor for whether they should be the steering motors or not.
WHS/CHS Robotics - Team 100 (2003-2006):
2006- Delphi's Driving Tommorow's Technology @ Davis | Imagery Award @ SVR | 2004- SVR Finalists (w/ 691 and 1280)| 2003- Delphi's Driving Tommorow's Technology @ Sac
pic: Vex Swerve v3 JVN Extra Discussion 22 09-08-2006 05:28 PM
pic: Swerve Assembly CD47-Bot Extra Discussion 3 01-23-2004 08:02 PM
pic: Swerve^2 Prototype CD47-Bot Robot Showcase 24 01-23-2004 12:11 PM
pic: Lego Swerve Drive CD47-Bot Robot Showcase 14 06-26-2003 04:19 PM
