Thread Tools |
Rating:
Display Modes |
Re: pic: Swerve! (Module)
Isn't simplicity one of the key elements of this design?
It doesn't look like you can directly swap the chain/sprocket element with two gears, so you're going to at least need 3, which means you'll need to add in another shaft and its bearings to support it, which means more machining, on top of the gear/gear stock you have to buy and machine as well. Anyways, shouldn't the encoders be measuring data off the wheel/the shaft that it's connected to? If so I don't see backlash being a problem, unless you're doing dead reckoning, which I'm sure our programming mentor has something to say against =P. I'm not advocating to keep the backlash, though, if you can get rid of it then that's good. |
Don |
Is there any interference where the chain is going to be? I think from this angle it looks like the chain is going through the side plates... if it were there.
oh and one more vote for keyway. DO NOT USE SET SCREWS!!! We had them on our transmission this year, and they were the biggest headache ever. We ended up getting the sprockets welded on at SVR. |
The reason i said no chain was not about breaking it was about miss alignment and the side loads that these modules might take. As far as gears go, an easy way to do this would just to make the top (smaller gear) larger, which would decrease the ratio and then change the ratio from the kit gearbox to each crab module. You can most likely match the ratios exactly with minimal effort. Encoders, yes measuring them directly on the wheel is optimal but you will still have some backlash issues. But in actuality you can put your encoder anywhere in your drive system and just use a simple function in your software to adjust for actual wheel speed. As for connecting the top I wasn't really worried about the alignment of the miter gears (as others have said spacers would be fine) I was just looking at the serviceability factor, especially if you decide to still use chain. |
Thanks for the feedback.
One more question for you: The vertical shaft is welded to the top plate. The top plate is 1/2" thick. Is this excessive? Would 1/4" plate work just as well? |
its a great design, and if you go about it right you can get complete direction control with only effecting your weight (i hate that constraint)
Nuttyman54 got it right, its a matter of distance rather than motor orientation.
#35 chain does not require any more or less tension to operate properly. As mentioned previously, it's a bit more forgiving about alignment, but if you're already planning on using a set of miter gears in your drive, you ought to be able to align even #25 chain with sufficient precision to make it work. You don't want to use chain in this application without an additional tensioning mechanism, however. Chain stretchs with time and use, so even if you've properly calculated the center-center distance to be a whole or half number of links, it won't stay that way for long. As the chain stretches, gravity is going to make sure that all of the slack ends up hanging off the bottom -- not engaging the sprocket and making the chain jump teeth. It won't be pretty. |
| pic: Vex Swerve v3 | JVN | Extra Discussion | 22 | 09-08-2006 05:28 PM |
| pic: Swerve! | =Martin=Taylor= | Extra Discussion | 15 | 07-07-2006 01:58 AM |
| pic: Swerve Assembly | CD47-Bot | Extra Discussion | 3 | 01-23-2004 08:02 PM |
| pic: Swerve^2 Prototype | CD47-Bot | Robot Showcase | 24 | 01-23-2004 12:11 PM |
