Go to Post Checklist: Robot on, thinkamajig set, autonomous set, safety bar pulled. - DonRotolo [more]
Unread 07-07-2006, 23:30
Joe_Widen's Avatar
Joe_Widen Joe_Widen is offline
FRC #1675 (The Ultimate Protection Squad)
Joe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud of
pic: Crabstyle v2
Finally in college =]
2009 Midwest Regional Champions - Thanks 111 and 1625
Unread 07-07-2006, 23:32
Jno
FRC #0610 (Crescent Robotics)
Re: pic: Crabstyle v2
Wow that looks really solid, maybe a bit too solid . How beefy is it? looks like you wouldn't have much weight to work with after the solid bottom frame.
Co-Founder of Taplytics.com
Unread 07-07-2006, 23:59
Joe_Widen's Avatar
Surprisingly, the whole frame and crab modules weigh 40 pounds.
Unread 08-07-2006, 00:00
My goodness, wow, geez, um, hrrm. Wow. That's got to be a welder's worst nightmare.
Is there going to be anything on top of it? Is FIRST raising the weight limit? I think you've definitely got the best of the best in terms of strength but the weight on that has got to be quite high. Perhaps tone it down a bit. More is not always merrier in this scenario.
EDIT: Saw the above post. Only 40 lbs? Are you sure material properties are set correctly? Well, on second thought, the wall thickness is only 2mm. Just seems a but too complicated to me though
Nice work on the model though. It is clear that must have taken some considerable time.
Unread 08-07-2006, 00:18
run the trap!!!
Team Role: Human Player
Looks like someones having fun with the frame generator!
-Philip J. Fry
Last edited by =Martin=Taylor= : 08-07-2006 at 00:20. Reason: nvm--just not used to metric
Unread 08-07-2006, 01:11
Arefin Bari's Avatar
AKA: Ari
FRC #0108 (SigmaC@T)
How much would it weigh including the transmissions you are planning on using, chain, motors?
Unread 08-07-2006, 01:15
Joe_Widen's Avatar
About the welding, I'm thinking of going to item....then I'll of course tone it down. Unless we get some super crazy good welder, item is my best friend.
Yes, I was having fun in frame generator. I think that 1/3 of your weight should go to chassis and drivetrain anyways.
Unread 08-07-2006, 01:31
Jno
it doesn't look like that 40 pounds includes motors, electronics, and all the wonderful small things that tend to be overlooked in CAD designs. Their is definitely more aluminum than their needs to be, your wheel modules are really nice, but the rest of the frame is a little excessive, like compare that to the stock frame. You could probably do without many of the cross supports, and even pushing the wheel modules out to the exterior of the frame would cut a lot of aluminum. Very nice CAD though.
Unread 08-07-2006, 01:52
DB_UPS's Avatar
DB_UPS DB_UPS is offline
tool or die that is the question?
AKA: Ryan Quinlan
FRC #1675 (The Ultimate Prtoection Squad)
DB_UPS has a spectacular aura aboutDB_UPS has a spectacular aura aboutDB_UPS has a spectacular aura about
Send a message via AIM to DB_UPS
I wouldn't do item. Item drivers me crazy cause i can't weld it together.
Unread 08-07-2006, 03:43
run the trap!!!
What motors will you be using to turn the modules?
I've heard some good and bad stuff about using the globe.
-Philip J. Fry
Unread 08-07-2006, 12:10
Joe_Widen's Avatar
Thanks for all the feedback everyone.
I'm thinking the globes or windows, not sure yet.
Well everything in that picture minus the cims weight 40 pounds. So I guess I better cut out some frame so I have more weight to play with. I'll try to get the other stuff in there in my next version.
Well I think it would weigh somewheres around 75 pounds with the turning modules and electrictronics.
Unread 08-07-2006, 13:23
CraigHickman
I like the solid design, except for the weight factor. Have you included chains, steering motors, bolts, and sensors into that weight?
As well as that, have you included the factor of mounting sensors? ie. Pot for turning, optical for speed, and so on... You really do need those for a crab drive, as we discovered when we made one for triple play.
Unread 08-07-2006, 14:49
Joe_Widen's Avatar
So i redesigned the Frame and saved four pounds. I guess I'm going with the window motors for the steering and the plastic chain hammond used for streering their crab drives. I'm guessing the streering mechanism will be abouth 5 pounds. Dont know until I make it, but thats my guess right now. I've already got spots for sensors, and lots of them. Otherwise, I've accounted for everything.
P.S. Im working on an electronics board.
pic: Crabstyle Joe_Widen Extra Discussion 12 04-07-2006 00:40
