Go to Post Gracious professionalism dictates that if you come to play, I must help you. - Al Skierkiewicz [more]
Unread 08-07-2006, 14:49
John Gutmann John Gutmann is offline
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
John Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant future
Send a message via AIM to John Gutmann Send a message via MSN to John Gutmann Send a message via Yahoo to John Gutmann
Re: pic: camera locked on light 143ft away!!!
Originally Posted by KenWittlief
the two lights are a fixed distance apart. Thats one side of the triangle. If you can measure the distance to both of them you have defined the lengths of all three sides, so you know where you are on the field
or knowing the angle to both lights will determine your position on one side of the field.
Remember that you would still be abel to be in 2 possible positions assuming that your not collinear to the 2 lights
pic: Green Light Dermot_135 Extra Discussion 17 19-01-2006 18:02
pic: 1501 2005 Camera Mount Chris_Elston Extra Discussion 5 03-01-2006 21:22
pic: Team 836 CMU Camera Bcahn836 Robot Showcase 2 12-02-2005 22:02
pic: 1351 camera mount sciguy125 Robot Showcase 6 05-02-2005 09:11
pic: Dave demonstrates how IR sensors can be used to call robots to light beacon CD47-Bot Extra Discussion 5 10-04-2004 19:44
