Re: pic: Vexanum 2.0
Question: are the rollers on a machanum wheels supposed to be set at 45 degrees or can they be set at different angles?
All machanum wheels I have seen have the rollers set at 45 degrees and the Vexanum 2.0 wheels look like they are set at a different angle. Perhaps someone could clarify this for me. |
oh and the 50% is not correct if i remember a thread from looong ago |
Sorry about the lack of reply. The roller are 3/8 id gas tubing from autozone with a sheet of brass foil from Joann fabrics on the inside to act as bushings. i am not sure about the angle of the wheels. Due to the stock vex plate design It was hard getting a consistent angle so its whatever angle it happens to be. While this is the only finished one currently those of you going to Ruckus off season comp will get to view them in action on my vex bot. Thankyou for the support.
