Go to Post Right, play to win. Play to win the event or play to win one match? This year, unfortunately, they are not the same thing. - Paul Copioli [more]
Unread 26-07-2006, 18:11
Re: pic: what is cooking
Well that's one heck of a reduction (in a fairly lightweight package too). But why the (what appears to be) 1:1 gearing on the last stage? Also, you should render that thing in Inventor Studio if you have it. It will look nice.
Also, nice job filleting all your corners. However, your machinist won't be thrilled with that really pointy triangle. What do you need to get in there, like an 1/8" or 3/16" tool?
Unread 26-07-2006, 18:26
Nuttyman54's Avatar
Mentor, Tactician
AKA: Evan "Numbers" Morrison
hmm...how to turn your CIM into a Taigene 101? looks nice.
Unread 26-07-2006, 20:42
Jeff 801's Avatar
Jeff 801 Jeff 801 is offline
Jeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond repute
thank you very much for pointing that out i must have missded it
Unread 26-07-2006, 21:49
CraigHickman
...That's a lot of reduction. I also like the lightening method. However, as Sanddrag mentioned, you may want to make your corner filets a little larger, just to be friendly to the machinist.
Unread 26-07-2006, 21:52
I really like how well you've done the "spokes" out from the bearing locations. It looks just great.
Unread 26-07-2006, 22:12
in between teams
AKA: Luke Van Oort
Are you sure those spokes can take the torque of the final output, I'm no ME, but they look a little small to me. The big gears look about the same size throughout the gearbox, as do the little ones. So, lets say the little one looks about 12-15 tooth and the big ones look about 60. There look to be about 5 reductions, so I'm thinking a final output of 1.7-5.2 rpms. So, either turning swerve modules (seems a bit excessive) or some sort of arm? I might be a bit off on the tooth counts (hopefully not too far) but whatever the exact number is, that is one heck of a reduction.
Team 1219: 2009 - Mentor
Unread 26-07-2006, 22:16
Bill_Hancoc's Avatar
Bill_Hancoc Bill_Hancoc is offline
Volkswagen Enthusiast
AKA: Bill Hancock
FRC #0573 (MechWarriors)
Bill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud of
Send a message via AIM to Bill_Hancoc
Judging by Luke's calc of final output RPM which sounds about right....im guessing a telescoping arm mechanism or other arm mechanism...looks very cool tho
MechWarriors 573
Unread 26-07-2006, 22:22
Jeff 801's Avatar
you got it it is for a telescoping arm designed by a 8th grader
Unread 26-07-2006, 22:18
Jeff 801's Avatar
Lukevanoort you were close the large gear is 70 teeth and the small gear is 12 teeth the final out put is 2.2 RPM
Unread 26-07-2006, 23:38
Nitroxextreme's Avatar
Nitroxextreme Nitroxextreme is offline
Relation to Mrs. Steve
AKA: Jon
FRC #1626 (Falcon Robotics ; 190 (Gompei and The Herd))
Nitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to behold
Send a message via AIM to Nitroxextreme
I agree with the torque concerns...
But how can you test something like that...the only thing I know of is COSMOS and that is only for solidworks.
I really like the wight reduction designs though and if there are no torque problems that is an amazing gearbox.
"He needed a chuck norris lesson in FIRST"...."I will give him a round house kick to the face...with gracious professionalism"
Unread 26-07-2006, 23:42
Morgan Gillespie's Avatar
Morgan Gillespie Morgan Gillespie is offline
I haven't any bullets
AKA: NPC / Mercury Rising
FRC #0025 (Raider Robotix)
Morgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond repute
Send a message via AIM to Morgan Gillespie
Where are you counting a fifth reduction I count four... I had someone else look and they also only see four.
Bristol-Myers Squibb Company
Events Competed:
-Duel on Delaware 05, 06, 07, 08 - Ramp Riot 05, 06, 07 08 - Brunswick Eruption 05, 06, 07 08 - PARC 06, 07, 08 - Monty Madness 0608 - Battle O' Baltimore 07 08 - Pascack Panda-monium - 08
__________________________________________________ _________________________
NJ 06, 07, 08 09 - UTC 07 -LV 06 - HI 08 - ATL CMP 06, 07, 08
Unread 27-07-2006, 01:47
There is stress testing in Inventor 11 and I believe in 10 also, but you've got to know how to use it. Testing for loads is the easy part. Predicting them is not.
Unread 27-07-2006, 02:03
run the trap!!!
Team Role: Human Player
Why not spare your machinist a tremendous amount of trouble and cut all those holes yourself with a hand drill?
Round holes will be faster to cut and stronger to boot. True, you will probably want your machinist to machine down the gears since they require balance; but the frame?
What do you plan on doing with your telescoping arm anyways? Any cool off-season projects a-brewing?
Nice work.
-Philip J. Fry
Unread 27-07-2006, 09:36
Jeff 801's Avatar
Nice work.
no it is just to have if next year we need it
Unread 27-07-2006, 13:48
Are you joking? It would take way more effort to hand drill a bunch of round holes than to throw the drawing in a CAM program and throw a plate in a CNC. I like it hoe it is and it the plates appear to be sufficiently strong (might be worried about the later stage gears though).
pic: What is 114 cooking up? CraigHickman Technical Discussion 13 20-06-2006 10:19
pic: What do u think bigboi146 Robot Showcase 9 21-03-2006 01:00
pic: WHAT IS THIS??? sgsdragons Robot Showcase 14 19-02-2006 11:35
What Team 568 is cooking up. Draqo Programming 1 10-03-2005 02:05
