Go to Post Welcome to FIRST, side effects may include...... - spears312 [more]
Unread 26-07-2006, 21:52
Re: pic: what is cooking
I really like how well you've done the "spokes" out from the bearing locations. It looks just great.
Unread 26-07-2006, 22:12
in between teams
AKA: Luke Van Oort
Are you sure those spokes can take the torque of the final output, I'm no ME, but they look a little small to me. The big gears look about the same size throughout the gearbox, as do the little ones. So, lets say the little one looks about 12-15 tooth and the big ones look about 60. There look to be about 5 reductions, so I'm thinking a final output of 1.7-5.2 rpms. So, either turning swerve modules (seems a bit excessive) or some sort of arm? I might be a bit off on the tooth counts (hopefully not too far) but whatever the exact number is, that is one heck of a reduction.
Team 1219: 2009 - Mentor
Unread 26-07-2006, 22:16
Bill_Hancoc's Avatar
Bill_Hancoc Bill_Hancoc is offline
Volkswagen Enthusiast
AKA: Bill Hancock
FRC #0573 (MechWarriors)
Bill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud of
Send a message via AIM to Bill_Hancoc
Judging by Luke's calc of final output RPM which sounds about right....im guessing a telescoping arm mechanism or other arm mechanism...looks very cool tho
MechWarriors 573
Unread 26-07-2006, 22:22
Jeff 801's Avatar
Jeff 801 Jeff 801 is offline
Jeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond repute
you got it it is for a telescoping arm designed by a 8th grader
Unread 26-07-2006, 22:18
Jeff 801's Avatar
Lukevanoort you were close the large gear is 70 teeth and the small gear is 12 teeth the final out put is 2.2 RPM
Unread 26-07-2006, 23:38
Nitroxextreme's Avatar
Nitroxextreme Nitroxextreme is offline
Relation to Mrs. Steve
AKA: Jon
FRC #1626 (Falcon Robotics ; 190 (Gompei and The Herd))
Nitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to behold
Send a message via AIM to Nitroxextreme
I agree with the torque concerns...
But how can you test something like that...the only thing I know of is COSMOS and that is only for solidworks.
I really like the wight reduction designs though and if there are no torque problems that is an amazing gearbox.
"He needed a chuck norris lesson in FIRST"...."I will give him a round house kick to the face...with gracious professionalism"
Unread 26-07-2006, 23:42
Morgan Gillespie's Avatar
Morgan Gillespie Morgan Gillespie is offline
I haven't any bullets
AKA: NPC / Mercury Rising
FRC #0025 (Raider Robotix)
Morgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond repute
Send a message via AIM to Morgan Gillespie
Where are you counting a fifth reduction I count four... I had someone else look and they also only see four.
Bristol-Myers Squibb Company
Events Competed:
-Duel on Delaware 05, 06, 07, 08 - Ramp Riot 05, 06, 07 08 - Brunswick Eruption 05, 06, 07 08 - PARC 06, 07, 08 - Monty Madness 0608 - Battle O' Baltimore 07 08 - Pascack Panda-monium - 08
__________________________________________________ _________________________
NJ 06, 07, 08 09 - UTC 07 -LV 06 - HI 08 - ATL CMP 06, 07, 08
Unread 27-07-2006, 01:47
There is stress testing in Inventor 11 and I believe in 10 also, but you've got to know how to use it. Testing for loads is the easy part. Predicting them is not.
Unread 27-07-2006, 02:03
run the trap!!!
Team Role: Human Player
Originally Posted by sanddrag
Also, nice job filleting all your corners. However, your machinist won't be thrilled with that really pointy triangle. What do you need to get in there, like an 1/8" or 3/16" tool?
Why not spare your machinist a tremendous amount of trouble and cut all those holes yourself with a hand drill?
Round holes will be faster to cut and stronger to boot. True, you will probably want your machinist to machine down the gears since they require balance; but the frame?
What do you plan on doing with your telescoping arm anyways? Any cool off-season projects a-brewing?
Nice work.
-Philip J. Fry
Unread 27-07-2006, 09:36
Jeff 801's Avatar
Nice work.
no it is just to have if next year we need it
Unread 27-07-2006, 13:48
Are you joking? It would take way more effort to hand drill a bunch of round holes than to throw the drawing in a CAM program and throw a plate in a CNC. I like it hoe it is and it the plates appear to be sufficiently strong (might be worried about the later stage gears though).
Unread 27-07-2006, 20:58
Drew Hopman's Avatar
Drew Hopman Drew Hopman is offline
Last Resort
FRC #0801 (HorsePower)
Drew Hopman is a jewel in the roughDrew Hopman is a jewel in the roughDrew Hopman is a jewel in the rough
Send a message via AIM to Drew Hopman Send a message via Yahoo to Drew Hopman
Thanks to ASRC Aerospace we can get this cut out on the wire edm that they have, either that or the water jet.... The machining ability that we have gained is amazing! I have looked over some of the stress factors and I think it should work because it is ¼” thick plate for the sidewalls. I would like to commend Jeffery on his skills considering he is only in 8th grade but has mastered inventor and has the ability to think in a mechanical nature will be a great asset to the team.
Unread 27-07-2006, 21:44
Nikhil Bajaj Nikhil Bajaj is offline
MATLAB Fan
Nikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond repute
Send a message via AIM to Nikhil Bajaj
I'd be more concerned about the strength of the gear teeth, especially in the later stages...if you take a CIM down to 2.2 rpm...you're going to be multiplying the max torque you can exert (it'll be around 90-100 oz-in when you trip the 40 A breaker) and if your free rpm is 2.2 rpm...then your gear ratio is somewhere around 2400...
240000 oz-in is a LOT of torque. be absolutely sure your gears can take it...you may have to step up the pitch a bit
but i totally agree...that amount of engineering proficiency and gumption in an 8th grader has the potential to be amazing...i look forward to future work.
Unread 28-07-2006, 13:51
Jeff 801's Avatar
it is not the small CIM but the large CIM to be clear.
Unread 28-07-2006, 14:32
MATLAB Fan
ah, well then...
free speed of around 2500 rpm down to 2.2...gear ratio of 1136...at your max current of 40 A, then that's 1136*240 oz-in = 272700ish oz-in, and then considering dynamic loading you need to multiply that by at least a factor of 2 for safety one would think. 550000 oz-in is a pretty hefty requirement. Although, to be honest you will probably never ever ever see anything in FIRST that requires that sort of reduction to do something. Unless next year's game is pick up an elephant and hang your robot on the bar carrying the elephant...which WOULD be pretty sweet to see aside from animal rights issues...
Also consider that every mesh you make decreases efficiency by a few percent.
Just things to keep in mind. Keep up the good work.
pic: What is 114 cooking up? CraigHickman Technical Discussion 13 20-06-2006 10:19
pic: What do u think bigboi146 Robot Showcase 9 21-03-2006 01:00
pic: WHAT IS THIS??? sgsdragons Robot Showcase 14 19-02-2006 11:35
What Team 568 is cooking up. Draqo Programming 1 10-03-2005 02:05
