Go to Post Defense shall reign supreme. - Corey Balint [more]
Unread 28-07-2006, 14:32
Nikhil Bajaj Nikhil Bajaj is offline
MATLAB Fan
Nikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond repute
Send a message via AIM to Nikhil Bajaj
Re: pic: what is cooking
Originally Posted by Jeff 888
it is not the small CIM but the large CIM to be clear.
ah, well then...
free speed of around 2500 rpm down to 2.2...gear ratio of 1136...at your max current of 40 A, then that's 1136*240 oz-in = 272700ish oz-in, and then considering dynamic loading you need to multiply that by at least a factor of 2 for safety one would think. 550000 oz-in is a pretty hefty requirement. Although, to be honest you will probably never ever ever see anything in FIRST that requires that sort of reduction to do something. Unless next year's game is pick up an elephant and hang your robot on the bar carrying the elephant...which WOULD be pretty sweet to see aside from animal rights issues...
Also consider that every mesh you make decreases efficiency by a few percent.
Just things to keep in mind. Keep up the good work.
Unread 28-07-2006, 14:39
Jeff 801's Avatar
Jeff 801 Jeff 801 is offline
Jeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond repute
Originally Posted by nikkibajbaj
ah, well then...
the large gear reduction is for the speed that the arm gos up
if it has that much strength than i need # 35 chain instead of # 25
Unread 28-07-2006, 15:04
MATLAB Fan
So are you just trying to reduce the speed of the motor? IE, is maximizing torque the concern or do you just want it to move slower?
Unread 28-07-2006, 16:00
Jeff 801's Avatar
both
pic: What is 114 cooking up? CraigHickman Technical Discussion 13 20-06-2006 10:19
pic: What do u think bigboi146 Robot Showcase 9 21-03-2006 01:00
pic: WHAT IS THIS??? sgsdragons Robot Showcase 14 19-02-2006 11:35
What Team 568 is cooking up. Draqo Programming 1 10-03-2005 02:05
