Re: pic: Vex Teaser: What's Art been up to lately?
Are you going to set this frame up as two or four wheel drive? Or do you just have other plans?
Be sure to post pics of the finished project. ![]() |
The motor here has a fairly high amount of torque for something it's size. Under a moderate load it runs at about 2,500 rpm, which is geared down through the worm gear 36:1 to about 69.4 rpm. Just to see how powerful it was, I geared it down an additional stage (using two 60t and two 12t gears, so as to split the load between them) using a 5:1 reduction. It was practically impossible to stop the output shaft of the stump-pulling second reduction. At the moment I am working on a much more complicated design that mechanically will calculate the difference between two input shafts. For example if both shafts were rotating CCW at the same RPM, the difference between the two would be zero. But if the two input shafts were moving at different speeds the output shaft would rotate in one direction (CW if shaft A is faster, and CCW is shaft B is faster) at a speed proportional to the difference of the two shafts. ![]() |
Where did you get the worm gears?
I was a bit frustrated at the lack of worm gears when my arm kept backdriving when I picked up mini tetras. |
Note: I bought them about two years ago for another project, so I'm not sure if they still carry the exact same gears. Any 24 pitch (or close enough) gear can mesh with Vex gears... ![]() |
Were you able to make a "South Pointing Chariot"? Was it to make your holonomic drive "driver centric"? Links from here might give you some ideas on differentials. http://en.wikipedia.org/wiki/South_Pointing_Chariot I thought the screwdrive one has some promise due to no requirement for bevel or planetary gears. You might also consider just doing the integration computationally, based on optical wheel encoders on the drive wheels or drag wheels. |
![]() Quote:
I'm guessing torque.
hey
hows it coming? I'd really like to see a movie of the bot in action. To see how much faster a bigger motor will be. I hope next season Vex will release beefier motors for torque or speed. |
| pic: 114 Bumper Art | CraigHickman | Extra Discussion | 6 | 03-20-2006 08:35 PM |
| pic: [Teaser]: When Vex meets Tetra | artdutra04 | Extra Discussion | 7 | 09-18-2005 02:31 PM |
| Image Discuss: 294 teaser, what's that? | CD47-Bot | Robot Showcase | 4 | 02-20-2003 12:09 AM |
| Image Discuss: 294 teaser, what's odd? | CD47-Bot | Extra Discussion | 3 | 02-03-2003 12:06 AM |
| change your profile lately? | Brandon Martus | Announcements | 0 | 03-04-2002 10:21 PM |
