Go to Post I'm always shocked when I see wiring having a bad hair day. - JaneYoung [more]
Unread 31-07-2006, 15:02
Andy A. Andy A. is offline
Getting old
FRC #0095
Andy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond repute
Re: Timing Belt Drive System
Originally Posted by Conor Ryan
You don't see too many motorcycles getting side impact crashes and still running properly.
I've got a bike that took a nice 40 mph dump onto asphalt I'd like you to meet. That was a fairly severe side impact.
It was fine. Me, not so much. It took a lot longer to get my self up and working then it did for me to pick up the bike and get it started. The belt driven transmission was fine, as was the chain to the wheel.
Belts are a fine way of transferring power in a robot. Like chains, gears, drive shafts, viscous couplings or any other means of transmission they require some care and attention on you're part. But no one said this robot stuff was going to be a cake walk.
-Andy A.
Timing Belt Clamp shorton Technical Discussion 10 18-07-2006 22:50
Timing Belt and Pulley Joe_Widen Technical Discussion 4 16-01-2006 13:41
what is or isn't a timing belt? archiver 2001 6 23-06-2002 23:26
two sided timing belt archiver 2001 3 23-06-2002 22:34
Timing Belt Recommendations? Eric Reed Technical Discussion 1 10-01-2002 00:25
