Go to Post Hopefully LMFAO will cross paths with FRC71. They've been shufflin' since 2002. - Taylor [more]
Unread 01-08-2006, 21:53
skimoose's Avatar
skimoose skimoose is offline
Parent/Mentor/Engineer
AKA: Arthur Dutra
FRC #0228 (GUS)
Team Role: Electrical
skimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond repute
Re: pic: Not the end of the Rainbow, but ....
This was the lightning storm that rolled through on 7/28/06. The driveway was asphalt, but I have seen similar damage to concrete as well. What looks like metal in this mess is actually more like a crude glass called a fulgurite. The line conductor an aluminum alloy known in the trade as AAAC (aluminum alloy - aluminum core) with such a low melting point I'm pretty sure most of the conductor vaporized. The fulgurite is glass formed as the silicas in the underlying soils melt in the intense heat, the bubbles are cooled glass that was forced to the surface probably by escaping gases.
This particular line was protected by a 65 ampere k-speed fuse. K speeds are the fastest melt time fuses available. Unfortunately, this was a high impedance fault and it took several minutes for the fuse to clear this arcing fault. I'd hate to guess at the initial temperatures (3,000-4,000F?), it looked like molten glass or lava (cherry red). The local fire department emptied 300 gallons of water on the asphalt after power was cut, and all they accomplished was to make a lot of steam. I revisited the site 6 hours after the fault, as the crews were making final repairs and the asphalt 3-4 feet from this burn was still soft to walk on (probably 150F)
Other than the downed line and loss of power, the homes in the area suffered no damage. The damage was localized in this case. Wires down like this don't tend to "dance" around, they just lay there and burn like a giant arc welder.
What's even scarier is this was the smaller of two lightning strikes. The larger strike about one quarter mile from this site cut a major three phase circuit down, and left a flaming 2 foot diameter, 4 inch deep fulgurite crater in the middle of a major asphalt road. Unfortunately, I didn't get to photograph that strike. The public works crew had dug up the road and patched it before I got there.
2009 CT Regional Motorola Quality Award
2010 VRC Connecticut Championship Winners & Amaze Award
2010 VRC Championship Divisional Energy Award
2010 WPI Regional Winner
2010 WPI Regional Engineering Inspiration Award
2011 WPI Regional Chairman's Award
2012 WPI Regional Finalists
Camera did not work for well at the regionals, but worked great at home. Alan Ing Programming 12 17-04-2006 17:43
pic: S.P.A.M's bot in the end tiffany34990 Extra Discussion 6 26-04-2005 13:18
pic: The end of nationals...everyone left at the same time CD47-Bot Extra Discussion 15 21-11-2004 18:50
She'll cheer for the Nimrods, but not for FIRST? Nick Seidl Chit-Chat 3 26-03-2004 15:03
pic: Lexan: Bulletproof, but not robotproof CD47-Bot Extra Discussion 6 21-03-2004 23:23
