Go to Post To sum it up... We know nothing. - BJC [more]
Unread 11-08-2006, 23:00
evanisthat!'s Avatar
evanisthat! evanisthat! is offline
Captin' Kassof
AKA: Evan Kassof
FRC #1902 (Exploding Bacon)
evanisthat! is just really niceevanisthat! is just really niceevanisthat! is just really niceevanisthat! is just really nice
Send a message via AIM to evanisthat!
Re: pic: 108 Rapid Crab Prototyping
Originally Posted by Ben Piecuch
Rapid Prototyping Content:
SLA machines run fairly quickly. I believe the units we used had a 1mm thickness interval, and each layer was done in a quick flash. However, I seem to recall that the cleanup of the part(s) was the most time consuming. The nylon is not very stable (due to temperature/light) so we always painted our models. That was after all the hand-sanding and detailing. Our turn-around time was a couple days.
Swerve Content:
Looks like a nice package. Is there only the single rotational bearing through the midline of the unit, or is it supported near the top as well? Also, are you making the swerve sprocket yourself, or is that an off the shelf part? Do you have an estimate cost for a full-up module? (I'd love to hear what it cost other teams to do a similar design.) I hope to see it in 2007!
BEN
Right now there is only one rotational bearing in the design, however a few people have commented on the stability of that during a match so in gen2 there will be 2 bearings, one low and one high. the sprocket is off the shelf but requires serious reworking, its a 70 tooth #25 chain with a 3 inch square cut in the middle... As cost goes...hmm... I have no idea. Working the parts would be the most expensive (especially the sprocket) as everything else is a standard part. When I am done reworking the whole design, I will post it with the inventor files for all to use. My final goal is to make it 2-speed, with independent swerve per side.
108!!!
2007 Las Vegas Xerox Creativity Award winners!
2007 Las Vegas Quarter Finalists, only alliance to challenge the champs!
2007 UCF Finalists... thanks to 1902, 179, and 386 for the crazy jump in!
2005 UCF regional quarter finalist...
2005 Midwest regional quarter finalist...
2005 UCF Website Winner
2005 Midwest "Delphi Driving Tomorrow's Technology" Award.
2005 Championship Curie Division Champions. (thanks to team 175 and team 33).
Unread 11-08-2006, 23:17
Arefin Bari's Avatar
AKA: Ari
FRC #0108 (SigmaC@T)
Since the first time I met you (you were in 8th grade and met you at the local FLL competition), I knew you would be the right hand man for team 108 someday. I am very impressed with the design, but I do question weight. The designs you have shown me, you were using quarter inch plates (I know this particular one wasn't made for a FIRST robot), but if you do plan to make a swerve drive for next year (for FIRST), I would suggest to look at those quarter inch plate you are using and take some weight out of there. Your overall chassis design (the one you showed me) looks very good. I would suggest to post it up here asap and get inputs from others.
... now post the picture up and go back and concentrate on school work, you gotta get to MIT remember? Good luck, Evan.
pic: 108 Gun Teaser carlos_polit Robot Showcase 8 04-02-2006 02:46
pic: when prototyping goes wrong Whalley Extra Discussion 13 01-02-2006 21:31
pic: 108... revealed CD47-Bot Robot Showcase 18 06-03-2004 18:40
pic: Rocket City Robotics (34) Rapid Prototyping System CD47-Bot Extra Discussion 8 08-01-2004 21:13
