Go to Post In my line of work, we affectionately refer to this approach as "Seagull Engineering". Why? Because we swoop in, flap around making a lot of noise and commotion, leave a big mess of "stuff" behind and then fly off. - billbo911 [more]
Unread 25-08-2006, 08:52
Hieb Hieb is offline
Hieb is a splendid one to beholdHieb is a splendid one to beholdHieb is a splendid one to beholdHieb is a splendid one to beholdHieb is a splendid one to beholdHieb is a splendid one to beholdHieb is a splendid one to behold
Re: pic: Variable Diameter Wheels? In Vex?! - pic 3
I started looking into this same idea last year after a discussion here about variable diameter wheels. Unfortunately the other mentors on my team felt it was beyond our capabilities, so I haven't had the opportunity to test it yet.
As far as making the wheels, my plan was to make a wheel model out of clay, then create a rubber mold and use liquid casting plastic for the wheels, with a section of axle embedded in the plastic. For the surface, wedge shaped sections of conveyor belting (the same type currently used by many teams) could be attached to the surface.
Variable Diameter Wheels greencactus3 Technical Discussion 71 12-12-2005 22:58
pic: omni wheels CD47-Bot Robot Showcase 15 03-03-2004 20:10
pic: Magic wheels CD47-Bot Robot Showcase 14 15-02-2004 21:33
pic: MVRT wheels CD47-Bot Robot Showcase 3 10-02-2004 14:58
pic: 222's wheels CD47-Bot Robot Showcase 14 11-12-2003 08:14
