Go to Post You can also always use the "Report Post" button on each post and that'll dispatch a carrier pigeon to each of our homes...or an e-mail if the carrier pigeons have taken the day off. - Madison [more]
Unread 27-08-2006, 18:24
Hieb Hieb is offline
Hieb is a splendid one to beholdHieb is a splendid one to beholdHieb is a splendid one to beholdHieb is a splendid one to beholdHieb is a splendid one to beholdHieb is a splendid one to beholdHieb is a splendid one to behold
Re: pic: Variable Diameter Wheels? In Vex?! - pic 3
Originally Posted by artdutra04
The only reason why I put the flat spot there, was to possible included recessed roughtop or wedgetop traction material, just to experiment with a "normal wheel" mode (the angles of the wheels do not change), and then the "variable diameter wheel mode" (the angle changes dynamically).
Also consider the flattened end of the wheel (opposite the "normal wheel" section) for a very high traction surface. In a competition where you want to stay in place and not be moved around easily, you turn your wheels 90 degrees, stop the motors, and turn your 'bot into a very nice little coffee table While the others are draining their batteries in a pushing match, you'd could be focusing on an entirely different aspect of the game.
Variable Diameter Wheels greencactus3 Technical Discussion 71 12-12-2005 22:58
pic: omni wheels CD47-Bot Robot Showcase 15 03-03-2004 20:10
pic: Magic wheels CD47-Bot Robot Showcase 14 15-02-2004 21:33
pic: MVRT wheels CD47-Bot Robot Showcase 3 10-02-2004 14:58
pic: 222's wheels CD47-Bot Robot Showcase 14 11-12-2003 08:14
