Go to Post You miss 100% of the shots you don't take. - AdamHeard [more]
Unread 02-09-2006, 15:12
Mike Nawrot's Avatar
Mike Nawrot Mike Nawrot is offline
NAwrot (a.k.a. jub jub)
AKA: Mike
FRC #0011 (MORT (Mount Olive Robotics Team))
Mike Nawrot is just really niceMike Nawrot is just really niceMike Nawrot is just really niceMike Nawrot is just really niceMike Nawrot is just really nice
Send a message via AIM to Mike Nawrot
Re: pic: Practice Mecanum Chassis
Awesome design. Nice and simple. There are a few improvements I see possible. Using 25 chain instead of what appears to be 35 will save some weight, because it will allow you to achieve a smaller pitch diameter on the drive sprocket, which will allow you to use a small sprocket on the wheels to maintain the same ratio, resulting in less material in sprockets and a shorter length of chain. Also, the rollers on you mecanums are all aligned in the same direction, and last I checked, they should oppose eachother to actually achieve omnidirectional motion. That's just a small detail though. Also, I'm a bit concerned about the chain on the rear wheels, since when the wheel assembly pivots, the chain will be forced to twist in a bit of an unnatural fashion. Other than that, the design is amazing in the lines of simplicity. And I like the green AM mecanums
[edit] I just realized that AM doesn't have the .step for both left and right wheels, so ignore my comment about the direction of the rollers.
"Its not just good... its good ENOUGH..." "Talk to me in two weeks" "It has to be done by Sunday" "Let me tell you a little something about FLL..."
"Physics don't apply on MORT robots" "What's today's roofigog?!" MIT class of 2012
pic: Mecanum Wheel Project - Rev. E Madison Technical Discussion 8 13-07-2006 13:31
pic: 2" Mecanum Wheel Tytus Gerrish Technical Discussion 17 22-04-2006 12:22
pic: Easy to make mecanum wheels mechanicalbrain Extra Discussion 15 06-10-2005 21:37
pic: 1" mecanum Tytus Gerrish Extra Discussion 8 04-10-2005 13:44
pic: Micro Mecanum wheel Tytus Gerrish Extra Discussion 6 12-05-2005 23:20
