Go to Post Don't be in a rush to build a robot until you know what robot it is you need to build. - Chris Fultz [more]
Unread 03-09-2006, 02:40
yongkimleng yongkimleng is offline
deus ex programmeur
AKA: James Yong
FTC #0747
yongkimleng is a jewel in the roughyongkimleng is a jewel in the roughyongkimleng is a jewel in the rough
Send a message via MSN to yongkimleng
Re: pic: Practice Mecanum Chassis
man this is getting exciting, I've never experienced mecanums before.
any way to flip the step import in solidworks?
As for the suspension, usually how much vertical movement would be enough to keep the wheels on the ground? Looks like the rubber is sufficient, but that depends on the overall weight of ur final bot right?
I was thinking of a pneumatic suspension where the pressure applied on each wheel could be adjusted as required (maybe not on-the-fly). anyone done that before?
pic: Mecanum Wheel Project - Rev. E Madison Technical Discussion 8 13-07-2006 13:31
pic: 2" Mecanum Wheel Tytus Gerrish Technical Discussion 17 22-04-2006 12:22
pic: Easy to make mecanum wheels mechanicalbrain Extra Discussion 15 06-10-2005 21:37
pic: 1" mecanum Tytus Gerrish Extra Discussion 8 04-10-2005 13:44
pic: Micro Mecanum wheel Tytus Gerrish Extra Discussion 6 12-05-2005 23:20
