Go to Post What is this "tired" of which you speak? Did it come in the KOP? - EricH [more]
Unread 04-09-2006, 15:50
Crazy Ivan's Avatar
Crazy Ivan Crazy Ivan is offline
The god of biscuits.
AKA: Jeff
FRC #0190 (Gompei and the H.E.R.D)
Crazy Ivan is a glorious beacon of lightCrazy Ivan is a glorious beacon of lightCrazy Ivan is a glorious beacon of lightCrazy Ivan is a glorious beacon of lightCrazy Ivan is a glorious beacon of light
Send a message via AIM to Crazy Ivan
Re: pic: Practice Mecanum Chassis
Originally Posted by M. Krass
After thinking some more about implementing a better suspension design, I think that I like your suggestion most. It's certainly simple and seems largely proven, especially after watching 40's robot move. My concern is that there may not be enough travel available with how I've interpretted your implementation, though. A similar rubber ring inserted into the U-channel with a bolt spanning through its center horizontally means that there's only about 1/2" of travel in each direction. It seems that this would be sufficient in all but the worst of circumstances, so I'm curious to learn more about what 40's experiences were regarding overall travel of the suspension.
I'll post another screenshot as soon as I clean up the new iteration a bit more.
From our experience, 1/2" should be more than sufficient for any playing surface out there. I would suggest putting the most amount of give in the system in the upward direction. So just having one 1" shock on the top would be enough.
pic: Mecanum Wheel Project - Rev. E Madison Technical Discussion 8 13-07-2006 13:31
pic: 2" Mecanum Wheel Tytus Gerrish Technical Discussion 17 22-04-2006 12:22
pic: Easy to make mecanum wheels mechanicalbrain Extra Discussion 15 06-10-2005 21:37
pic: 1" mecanum Tytus Gerrish Extra Discussion 8 04-10-2005 13:44
pic: Micro Mecanum wheel Tytus Gerrish Extra Discussion 6 12-05-2005 23:20
