Go to Post Viva La FIRST Revolucion! - phrontist [more]
Unread 05-09-2006, 22:14
negfrequency's Avatar
negfrequency negfrequency is offline
the guy with the drawings
AKA: Willomatic
FRC #1559 (Devil Tech)
negfrequency is just really nicenegfrequency is just really nicenegfrequency is just really nicenegfrequency is just really nicenegfrequency is just really nice
Send a message via AIM to negfrequency
Re: pic: Ratchet
alright when i put this design in mind i was hoping to make an adjustable ratchet using 6 adjustable walls so to speek around the nut that could be locked into place. Turns out there are already adjustable ratchets that work similar to those plates of pins you put over your hand and it forms to shape to your specific hand as each individual pins lift. now i want one.
www.evolved-ideas.net
-KOP CAD parts available for download
You know your me if.....
5) your 91 honda civic dx drives @ warp .000005376, not 60 mph
4) You know what "Bi-directional parametric associativity" is
3) Playing Diabolo does NOT mean you are a level 24 mage.
2) You've discovered you can rearrange the letters in William to spell "I am Will".
1) Your bicycle is 3 times more expensive than your car.
Bi-directional ratchet need help Xufer Technical Discussion 13 31-01-2005 14:27
Ratchet/slip bearing? Ianworld Technical Discussion 6 20-01-2005 13:04
Anyone missing a Crasftman Ratchet Set from Mayhem Kyle Fenton Off-Season Events 0 01-06-2003 14:23
