Re: pic: Inside the torque multiplier
Interesting....that has the same principle as an oil pump...but i wonder how it 'multiplies' torque
looks messey though |
Basically, its a gear reduction. This is useful |
The low-cost (read: Harbor Freight) unit does not have a conventional epicyclic gear set. It appears to operate differently. The input gear center hole pilots on an eccentric section of the input shaft, causing its tooth engagement point on the outer ring to revolve. The input gear revolves 33 times for every single revolution of the output gear, and both gears react against the teeth of the stationary ring. And as mentioned earlier, the gears are loosely pinned together in six places, allowing relative freedom of movement between the gears of about one tooth pitch. Also, the output gear rotation is opposite that of the input gear. So to loosen a lug nut you turn the crank clockwise. Maybe this really is a kind of epicyclic gear set, with the sun gear replaced by an eccentric -- sort of like a gear with one tooth?I'm hoping someone with more experience in gear set design will jump in here an enlighten us to the mystery of this gear system. I am actually an electrical engineer, with just enough knowledge of mechanisms to be dangerous. Last edited by Richard Wallace : 19-09-2006 at 22:03. |
These are great drives because you get tremendous turndown (torque multiplication) in a very compact package. There is a company called Harmonic (at least that is what they used to be called) that makes a similar drive but very elegant. The inner "gear" is actually flexible, such that it is deformed into an ellipse that meshes the ring gear in two places. The teeth are very fine pitch. Therefore, the one tooth difference between inner and outer gears makes for a huge turndown (something like 75:1 or better in a transmission not much larger than a coupling), and the drive is incredibly smooth. The biggest advantage in our application was the lack of any perceptible gear noise, as the drive was for cooling rolls on a polycarbonate sheet line. Any ripple would have produced an optically perceptible imperfection in the lexan. Very cool, but expensive.
I did not recognize the similarity of the harmonic drive to the low-cost lugnut remover gear set. |
The way the harmonic drives operate is explained here in detail: http://www.harmonicdrive.net/referen...ingprinciples/
This is an interesting explanation of how a multi-speed planetary transmission operates: http://www.railcar.co.uk/mechanical/gears/work.htm This was actually for a locomotive: http://www.railcar.co.uk/mechanical/gears/intro.htm And this is a great animation. You can click the buttons and see the different modes of operation: http://www.mekanizmalar.com/transmission.html Last edited by Dick Linn : 20-09-2006 at 16:42. |
I usually don't like to revive dead threads. However, when I saw a description of how hypocycloidal gearing works, it immediately reminded me of the lugnut remover. The animation in the link above seems to capture the operation of that gadget better than any of the previous explanations.
The wiki comes through with a decent explanation, http://en.wikipedia.org/wiki/Epicyclic_gearing but it won't touch a good machine design book like Shigley or Norton. The Lindeburg PE exam reference book is the best explanation I have but I can't post it. http://ppi2pass.com/ppi/PPIShop Pete edit: When you say it operates like an oil pump I'm a little confused. Do you mean it's like a gearotor hydraulic pump? Last edited by Peter Matteson : 20-09-2006 at 16:09. Reason: see post |
| pic: Inside Team 698 Teaser | Alex698 | Extra Discussion | 3 | 09-03-2006 00:46 |
| A tour inside the RC | Rickertsen2 | Control System | 15 | 10-01-2006 18:07 |
| Information on gears inside the FP Gear Box? | David Guzman | Technical Discussion | 2 | 19-05-2005 23:09 |
| Grease inside the Drill Motor gear box? | archiver | 2000 | 2 | 23-06-2002 23:07 |
