Go to Post Surprise! There is no ideal alliance. As soon as you think you have a winning strategy, someone WILL figure out how to beat it. - Tom Bottiglieri [more]
Unread 19-09-2006, 21:32
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Re: pic: Inside the torque multiplier
Originally Posted by Conor Ryan
It multiplies the torque, by dividing the revolutions per minute. Since the power output cannot be greater than the power input.
Basically, its a gear reduction.
This is useful
Thanks for that link, Conor. The handtorque multiplier example shown there is an industrial grade unit with an epicyclic gear set.
The low-cost (read: Harbor Freight) unit does not have a conventional epicyclic gear set. It appears to operate differently. The input gear center hole pilots on an eccentric section of the input shaft, causing its tooth engagement point on the outer ring to revolve. The input gear revolves 33 times for every single revolution of the output gear, and both gears react against the teeth of the stationary ring. And as mentioned earlier, the gears are loosely pinned together in six places, allowing relative freedom of movement between the gears of about one tooth pitch. Also, the output gear rotation is opposite that of the input gear. So to loosen a lug nut you turn the crank clockwise. Maybe this really is a kind of epicyclic gear set, with the sun gear replaced by an eccentric -- sort of like a gear with one tooth?
I'm hoping someone with more experience in gear set design will jump in here an enlighten us to the mystery of this gear system. I am actually an electrical engineer, with just enough knowledge of mechanisms to be dangerous.
Richard Wallace
since 2003
pic: Inside Team 698 Teaser Alex698 Extra Discussion 3 09-03-2006 00:46
A tour inside the RC Rickertsen2 Control System 15 10-01-2006 18:07
Information on gears inside the FP Gear Box? David Guzman Technical Discussion 2 19-05-2005 23:09
Grease inside the Drill Motor gear box? archiver 2000 2 23-06-2002 23:07
