Go to Post Arguing or defending is not how to accept feedback. Someone who shares their opinion cannot be wrong - their opinion is their opinion. - DonRotolo [more]
Unread 19-09-2006, 22:00
Andrew Blair's Avatar
Andrew Blair Andrew Blair is offline
SAE Formula is FIRST with Gasoline.
FRC #0306 (CRT)
Andrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond repute
Send a message via AIM to Andrew Blair Send a message via Yahoo to Andrew Blair
Re: pic: Inside the torque multiplier
Originally Posted by Bill_Hancoc
Interesting....that has the same principle as an oil pump...but i wonder how it 'multiplies' torque
looks messey though
This is a good question: anybody have a good explanation for an epicyclic gear drive?
Reading makes a full man, conference a ready man, and writing an exact man.
-Sir Francis Bacon
"Any intelligent fool can make things bigger, more complex, and more violent. It takes a touch of genius -- and a lot of courage -- to move in the opposite direction."
-Albert Einstein
Unread 20-09-2006, 07:11
John Neun John Neun is offline
FRC #0020 (Rocketeers)
John Neun has a reputation beyond reputeJohn Neun has a reputation beyond reputeJohn Neun has a reputation beyond reputeJohn Neun has a reputation beyond reputeJohn Neun has a reputation beyond reputeJohn Neun has a reputation beyond reputeJohn Neun has a reputation beyond reputeJohn Neun has a reputation beyond reputeJohn Neun has a reputation beyond reputeJohn Neun has a reputation beyond reputeJohn Neun has a reputation beyond repute
These are great drives because you get tremendous turndown (torque multiplication) in a very compact package. There is a company called Harmonic (at least that is what they used to be called) that makes a similar drive but very elegant. The inner "gear" is actually flexible, such that it is deformed into an ellipse that meshes the ring gear in two places. The teeth are very fine pitch. Therefore, the one tooth difference between inner and outer gears makes for a huge turndown (something like 75:1 or better in a transmission not much larger than a coupling), and the drive is incredibly smooth. The biggest advantage in our application was the lack of any perceptible gear noise, as the drive was for cooling rolls on a polycarbonate sheet line. Any ripple would have produced an optically perceptible imperfection in the lexan. Very cool, but expensive.
Unread 20-09-2006, 09:23
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Thanks, John. For many years I've been using a Harmonic Drive Model PCR-5C 100:1 reducer as part of low-speed motor tester. [Note: this reducer is now obsolete, replaced by the CSG series, I think.] We use this tester to measure cogging, ripple, and frictional torques developed by brushless permanent magnet motors at 2 RPM. The Harmonic Drive unit operates with negligible backlash, is very quiet, and as you pointed out it provides very high reduction ratio in a compact package. It is also not cheap.
I did not recognize the similarity of the harmonic drive to the low-cost lugnut remover gear set.
Richard Wallace
since 2003
Unread 20-09-2006, 16:37
Dick Linn's Avatar
Dick Linn Dick Linn is offline
no team (Synergy)
Dick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond repute
Send a message via AIM to Dick Linn
The way the harmonic drives operate is explained here in detail: http://www.harmonicdrive.net/referen...ingprinciples/
This is an interesting explanation of how a multi-speed planetary transmission operates: http://www.railcar.co.uk/mechanical/gears/work.htm This was actually for a locomotive: http://www.railcar.co.uk/mechanical/gears/intro.htm
And this is a great animation. You can click the buttons and see the different modes of operation: http://www.mekanizmalar.com/transmission.html
Richard Linn
Proud father of Marine LCpl. Karl R. Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 01-08-2007, 17:45
I usually don't like to revive dead threads. However, when I saw a description of how hypocycloidal gearing works, it immediately reminded me of the lugnut remover. The animation in the link above seems to capture the operation of that gadget better than any of the previous explanations.
Richard Wallace
since 2003
Unread 20-09-2006, 16:06
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
Substitute the word planetary for epicyclic. It's another word for the same thing.
The wiki comes through with a decent explanation, http://en.wikipedia.org/wiki/Epicyclic_gearing but it won't touch a good machine design book like Shigley or Norton. The Lindeburg PE exam reference book is the best explanation I have but I can't post it.
http://ppi2pass.com/ppi/PPIShop
Pete
edit: When you say it operates like an oil pump I'm a little confused. Do you mean it's like a gearotor hydraulic pump?
Thank-you 294 & 67
www.bobcatrobotics.org
pic: Inside Team 698 Teaser Alex698 Extra Discussion 3 09-03-2006 00:46
A tour inside the RC Rickertsen2 Control System 15 10-01-2006 18:07
Information on gears inside the FP Gear Box? David Guzman Technical Discussion 2 19-05-2005 23:09
Grease inside the Drill Motor gear box? archiver 2000 2 23-06-2002 23:07
