Go to Post EVERYONE on the team is offered the same opportunities to be a team player, it is up to each person to step up and play the game. - MariaCastro [more]
Unread 21-09-2006, 21:06
Astronouth7303's Avatar
Astronouth7303 Astronouth7303 is offline
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Astronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud of
Re: pic: CRT Goes To The Football Game!
Any whitepaper on this? We would love to use it ourselves for the same purpose.
Unread 22-09-2006, 19:08
Andrew Blair's Avatar
Andrew Blair Andrew Blair is offline
SAE Formula is FIRST with Gasoline.
FRC #0306 (CRT)
Andrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond repute
Send a message via AIM to Andrew Blair Send a message via Yahoo to Andrew Blair
No white paper that I know of, but it's quite simple.
1. Buy ~ 3" pressure rated schedule 40 PVC pipe, depending on what diameter barrel you want. 3" works well for t-shirts and small foam balls. You'll be using this for both the barrel and tank.
2. Buy an irrigation valve with large diameter bore. (Ours is a 3/4" throat, 24 volt irrigation valve from Lowes. It ran about $17 and has worked perfectly. It's just a simple solenoid, so 12 volts works fine with it)
3. Buy appropriate end caps, fittings, tubing, and good, relatively high pressure PVC glue (It'll tell you it's best rating on the can. Ours is a tan glue)
4. Put it together.
It's not much of a how to, but it'll get you started. Um, one thing concerning the PVC air tank- conversation recently generally agrees that even pressure rated pipe has a serious possibility of catastrophic failure, so be careful if using our setup. We are considering adding some shielding or containment devices around the tank just in case. Even better, use an actual air tank. But it's important to have all openings be at least the size of the valve gate, otherwise you'll bottleneck.
As for the barrel, just start with a long length, and test it, shortening the barrel until you get good results. Different projectiles will like different lengths.
Have fun, ours never seems to get old, and the community really likes it, so it's really a good investment! Any more questions you have I'd be happy to answer.
Reading makes a full man, conference a ready man, and writing an exact man.
-Sir Francis Bacon
"Any intelligent fool can make things bigger, more complex, and more violent. It takes a touch of genius -- and a lot of courage -- to move in the opposite direction."
-Albert Einstein
Unread 22-09-2006, 20:21
Dan Petrovic's Avatar
FRC #0166 (Chop Shop)
That is awesome! Keep up the good work!
Unread 23-09-2006, 18:26
wendymom's Avatar
wendymom wendymom is offline
Team Mom
AKA: Wendy Austin
FRC #5816 (Gra-V)
wendymom has a reputation beyond reputewendymom has a reputation beyond reputewendymom has a reputation beyond reputewendymom has a reputation beyond reputewendymom has a reputation beyond reputewendymom has a reputation beyond reputewendymom has a reputation beyond reputewendymom has a reputation beyond reputewendymom has a reputation beyond reputewendymom has a reputation beyond reputewendymom has a reputation beyond repute
I want one!!!!!! Exploding Bacon....are you listening???????
Its really cool.
The "anything goes" game! mechanicalbrain Games/Trivia 30 04-09-2006 13:34
pic: The BEAST Goes Down! CD47-Bot Extra Discussion 5 22-04-2004 11:14
pic: 73 goes for the doubler at Buckeye CD47-Bot Extra Discussion 5 01-04-2004 05:28
FIRST Annual, All Star Football Game or Mini Tornement archiver 2000 11 23-06-2002 22:14
