Go to Post note to self: do not use robot to retrieve cars from water. - Greg Marra [more]
Unread 23-09-2006, 14:52
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Re: pic: Team 306's (maybe) roller system.
In my opinion, that is too more than enough power for a roller intake system (assuming balls roughly the same size and weight there were in previous games). You are allocating two of the stronger motors you are allowed, not only to a single task, but a task that can typically be acheived with much less power. We used a single mini-bike in 06, and it worked fine (our hopper did jam on occasion though, but the intake had little to do with that). We probably could (and should) have used even a lesser motor (as the minibike could, on a full battery, actually launch the balls out of the top of the robot), and allocated the shooter the 2nd minibike motor.
pic: Team 116 Modular Control System dlavery Robot Showcase 42 21-10-2007 11:15
pic: 1902's intake roller Dan Richardson Robot Showcase 7 14-02-2006 20:59
pic: Team 612 Drive System RoboMadi Robot Showcase 7 08-02-2006 16:38
pic: rookie team 1481's 6 cylinder pneumatic system. (very organized isn't it...) CD47-Bot Robot Showcase 3 02-02-2004 23:19
Animatrix (maybe spoilers, maybe no.) Frank(Aflak) Chit-Chat 8 03-06-2003 22:14
