Go to Post Theres just something about a big honkin' robot that's irresistible. - seanwitte [more]
Unread 29-09-2006, 07:53
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
pic: Annotated Chassis Drawing
--Madison--
...down at the Ozdust!
Unread 29-09-2006, 07:57
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Re: pic: Annotated Chassis Drawing
Looks impressive.
A question about the module pivots, though: is there anything inside the frame to reinforce the pivot points? It looks like you've got a 7/8" hole in 1"×1"×1/16" aluminum tube. Especially on the perimeter of the frame, that has the potential to get rather bent during competition, unless reinforced.
While I have your attention, is this intended to be used with a sprung suspension, or a powered mechanism to drive the pivots?
Unread 29-09-2006, 10:55
Jeremiah H Jeremiah H is offline
FRC #0393 (Full Metal Jackets)
Jeremiah H is a glorious beacon of lightJeremiah H is a glorious beacon of lightJeremiah H is a glorious beacon of lightJeremiah H is a glorious beacon of lightJeremiah H is a glorious beacon of light
Looks mighty slick. Two questions-
-How's traction/"pushing power" in the front/back and side/side directions?
-How's maneuverability?
Keep us posted on how it works out- our team may be interested in that sort of drive this year.
Johnson & Johnson Sportsmanshp Award, Buckeye '07
Johnson & Johnson Sportsmanshp Award, VCU '07
Finalists at Pittsburgh '06
Pittsburgh GM Industrial Design Award '06
Voted 2006 Boilermaker 'Best Defensive Robot' '06
Unread 29-09-2006, 12:42
Bengineer
Along with what Tristan said, the frame looks fairly light. I wouldn't be surprised if the frame flexed enough to make do without the drive module pivots. Though, knowing your design skills, I'm assuming you'll have more structure going on top to stiffen the whole assembly, hence, making my point worthless.
Do you plan on rivetting/welding/bolting the frame?
However, I'm at a loss as to how the tensioning slots work. Since the idler moves with the gearbox module, it seems like all you're doing is changing the tangent point of the chain with the wheel. I would expect the idler to move with respect to the gearbox, or to just use an eccentric idler/guide. That could greatly simplify the entire assembly.
Overall it looks very nice and clean. One of the better Mecanum setups I've seen.
BEN
Unread 29-09-2006, 12:55
Rich Wong Rich Wong is offline
NYC FIRST Planning Committee Member
no team (NYC FIRST)
Rich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond repute
Send a message via AIM to Rich Wong
Excellent CAD drawing.
If I was a potential sponsor, I would briefly like to see a work flow chart, concepts, designs showing different phases of development.
I would also like to know how the parts of the drive Tran can be fabricated, the work plus cost involved with the machining and assembly.
The possible use of outside services to perform any advanced machining of parts, the testing phases and the redesign phase that the teams must go through. Tie it all up with the learning and skills the students are receiving from working on this design.
This all translates to "what am I getting for my sponsorship dollars and how the money benefiting the students."
(That's just my opinion) Again, very nice design.
popularis de ob instinctus agnitionis scientia technologia
Home website: www.nycnjfirst.org
Member of NEMO & e^(i*pi)+1 Fraternity.
Member of Friends of Robots
Member of NYCFIRST Planning Committee
Unread 29-09-2006, 12:59
nuggetsyl's Avatar
nuggetsyl nuggetsyl is offline
FRC #0025
nuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond repute
Originally Posted by M. Krass
Thread created automatically to discuss this image in CD-Media.
WOW that kinds looks like our new drive train except our new drive only has a total of 3 wheels. We figured we will need the weight this year for a lifting mech.
00,12Championship winner
03,06,08 Championship finalist
02A,03C,06N,08C,11N,12G Division winner
00,03,06,07,08,10,12 NJ / MAR winner
11 VCU winner
06,10 Las Vegas winner
12 MAR Mt Olive
red is for team 348
Unread 29-09-2006, 13:57
Madison's Avatar
FRC #0488 (Xbot)
Originally Posted by Tristan Lall
Looks impressive.
The pivot itself is a 3/8" Grade 8 bolt. The 7/8" hole you see if clearance for a ratchet, but it may turn out that we'll run the bolt through both walls of each tube. In the past, we've had some overzealous kids overtighten bolts and crush tubing more than any robot has ever done.
The suspension is 'sprung,' as it were. The first iteration will use the compression of the rubber dampener as its spring. I'm hopeful this will allow us to easily change the resistance provided by the suspension as well as ride height by altering the properties of the dampener.
Thanks. These sorts of drives aren't built for fighting other robots. If you get into a place where your mecanum or omnidirectional drive needs to push another robot, you've probably made a bad decision somewhere, I think. We'll have a better idea for what the traction and losses will be like once we have the wheels on hand -- hopefully by the end of next week.
We built a very, very light frame for the 2006 game that consisted of four pieces of 1"x1"x1/16" Aluminum tube notched and bolted together to form a tic-tac-toe pattern, onto which we snapped drive pods that had omniwheels at the corners and Skyways in the middle for a 6WD arrangement. That chassis has been beaten up pretty badly and isn't square or level anymore, so I'm anticipating similar abuse here and including the suspension. I don't have anything planned for above what's shown for our prototype unless it happens that we need to stiffen things up considerably more, but of course for competition there'll be a lot of structure added.
We have to outsource welding to a local community college instructor (who sometimes likes to let his students practice on our parts) and so I'm hesitant to design anything at all for welds. The plan now is to bolt the frame together.
The tensioning slots are tangent to the wheel and sprocket, so by moving the gearbox up we change the center-center distance between the sprockets. The chain length can be changed by about 2 links by moving things up and down.
Does that clear the confusion up? The "idler" will be driving an optical encoder, so I want positive engagement with the chain and adjustability elsewhere.
We develop these plans each Fall as a way of giving students hands-on interaction with tools in our lab before the season begins. We have access to some pretty sophisticated tools, each with a unique learning curve, and so we'd waste a lot of time teaching their use during the build season. We'd make all of the parts ourself except, obviously, for the COTS stuff. We have a HAAS CNC machining center, a DynaCNC plasma cutter, a CO2 laser cutter and a big 'ol lathe in addition to more typical things like bandsaws, drill presses, and the sort.
We chose a mecanum chassis because of the close integration required between mechanical, software and electrical components. We've become pretty good at making sound mechanical devices, so it's now time to learn more about control systems. I think this will be something that will engage a lot of the students who so far haven't been interested in getting their hands dirty with the power tools. It'll also end up as an impressive showpiece, we hope, for demonstrations and outreach.
Depending on how well this goes together, we've got some other designs coming down the line that we'll take a stab at before the year ends. Those projects are a bit more traditional, though -- an improved 6WD design, an 8-speed, shift-on-the-fly transmission... y'know, boring stuff
Are you using traditional omniwheels for a three-wheeled drive or mecanums in some arrangement that I can't wrap my head around this time of the morning?
I sure hope we don't need a lifting mechanism in 2007. We decided last night that we're tired of driving around giant, cumbersome robots and our next machine will be two feet tall and seventy-five pounds, no matter its intended goal
--Madison--
Unread 29-09-2006, 19:36
techtiger1's Avatar
Coach Drew?!?!
AKA: Drew Disbury
FRC #1251 (TechTigers)
I don't think this is as strong as some people think it is there is no cross support for the box tubes that make up the wheel wells, hit the side of that robot enough times it will start to bow in trust me.
Team 1251 The TechTigers
2006 Palmetto Regional Winner
2007 Orlando Regional Winner
2008 Orlando Regional Winner
2010 Orlando Regional Winner
Unread 29-09-2006, 20:30
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
I like your idea for suspension, that was a major problem on our robot last year. We had to go 2 wheel drive to save weight at the last minute, and at all of the matches our robot was out of square (despite our wheel adjustments). It was a real pain to drive.
Unread 30-09-2006, 13:32
CraigHickman
It might just be the way I'm lookin at this, but it seems that all of the rollers on the mecanums are in the same orientation. Isn't the concept of mecanums to have 45 degree offsets?
Unread 30-09-2006, 13:58
Madison's Avatar
FRC #0488 (Xbot)
You're right -- I've just been too lazy to mirror the model of AndyMark mecanum wheels to get a complete set.
--Madison--
Unread 15-11-2006, 21:41
DustinB_3 DustinB_3 is offline
FRC #0935 (Railerobotics)
DustinB_3 is an unknown quantity at this point
What code are you using for your setup? We're working on a mecanum setup very similar except that we're having problems programming it. Especially turning and strafing at the same time. Sorry if this is a little off topic
Unread 01-12-2006, 10:34
railerobotics's Avatar
railerobotics railerobotics is offline
FRC #0935
railerobotics will become famous soon enough
I was wandering if you made the AndyMark Wheels in inventor or down loaded them from some where? If you made them what did you do to get the angled tabs right.
Unread 01-12-2006, 14:59
Madison's Avatar
FRC #0488 (Xbot)
I downloaded the model from the AndyMark website.
I'm sorry I didn't see this sooner. I know you guys seem to have finished up your drive, so would you still like a look at our code? I think I have a copy of the completed code, but since I don't do any programming at all, I can't be sure until I harass our programming folks.
--Madison--
Unread 01-12-2006, 17:15
Currently we are using a modified version of some vex holomonic code that I found on chief delphi. It works but its hard to control and I'm sure there's a more effecient way to do it.
pic: My First time.....(CAD car drawing) negfrequency Extra Discussion 13 26-06-2006 23:12
pic: Top Chassis Rick TYler Robot Showcase 1 04-02-2006 19:13
pic: 195 Chassis Tom Bottiglieri Robot Showcase 14 09-02-2005 11:16
Professional electronics board assembly [annotated collector's edition] Geoff General Forum 7 17-02-2004 21:57
pic: Seven Chassis-es! CD47-Bot Robot Showcase 2 01-02-2004 15:03
