Go to Post If robotics is bad for you, well then I guess I'm gonna die. At least I'll die happy. - karinka13 [more]
Unread 31-10-2006, 06:52
chris31 chris31 is offline
Team 2021 Captain
AKA: Chris Davidson
FRC #2021 (FA Robotics)
chris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond repute
Send a message via AIM to chris31
Re: pic: brand new custom built control center
Look nice! Maybe a logo or some color to spice it up. Maybe some buttons and switchs if you 2nd driver prefers that over using a joystick.
Unread 31-10-2006, 09:03
Tim Baird's Avatar
Tim Baird Tim Baird is offline
Design Ninja
FRC #0126 (Gael Force)
Tim Baird has a reputation beyond reputeTim Baird has a reputation beyond reputeTim Baird has a reputation beyond reputeTim Baird has a reputation beyond reputeTim Baird has a reputation beyond reputeTim Baird has a reputation beyond reputeTim Baird has a reputation beyond reputeTim Baird has a reputation beyond reputeTim Baird has a reputation beyond reputeTim Baird has a reputation beyond reputeTim Baird has a reputation beyond repute
Send a message via AIM to Tim Baird
You could always put a toggle switch on there with a flip-up guard on it.
Tim Baird
FRC Alum and FRC/FLL Volunteer
Project Engineer @ Nypro
History:
Gael Force 126: 1999-2000
WPI 190: 2001-2004
Gael Force 126: 2005-2010
Event Volunteer Only: 2011-Present
Unread 31-10-2006, 12:08
pyro20911d
VERY NICE!!! It has a modern and clean look to it
there's only one thing
it needs some sweet lights inside of it.....seeing as it's made of frosted Lexan and or white nylon, if a few blue LEDs were placed inside it would have an awesome soft blue glow eminating from it
Unread 31-10-2006, 12:19
Tbush173's Avatar
Tbush173 Tbush173 is offline
AKA: Travis Bush
FRC #0173 (RAGE)
Tbush173 is on a distinguished road
I would put some green ooze, maybe some biohazard logos. All on a black background with some green LED's. Just use your team's theme (plague) to come up with a good design.
Unread 31-10-2006, 20:01
Astronouth7303's Avatar
Astronouth7303 Astronouth7303 is offline
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Astronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud of
There's only one that's definitely cooler than that. And it had a dashboard display built-in.
Unread 31-10-2006, 20:24
eshteyn's Avatar
eshteyn eshteyn is offline
WOOPS! shorted the deep cycle batt.
AKA: the supply seargent, Eugene
FRC #0375 (the robotic plague)
eshteyn is just really niceeshteyn is just really niceeshteyn is just really niceeshteyn is just really niceeshteyn is just really nice
Send a message via AIM to eshteyn Send a message via Yahoo to eshteyn
you know, i haven't thought of that, now i will have to annoy my mentor to get an old laptop and make a built in display, thanks for the great idea
Championship - Delphi "Driving Tomorrows Technology"
Unread 31-10-2006, 20:47
Andy A. Andy A. is offline
Getting old
FRC #0095
Andy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond repute
I would suggest modifying the window to be hinged, allowing easy access to the OI underneath.
A 'roll bar' of sorts, extending from the font edge up, that would in the event of the unit falling upside down would prevent the joysticks from hitting the ground. It would also allow you to place the control system down, with the handle facing up.
Looks good. I prefer it to the painted and cathoded look. Try brushing and polishing the aluminum just before a regional. It won't last long, but it does look great.
-Andy A.
Unread 31-10-2006, 20:51
Billfred's Avatar
Billfred Billfred is offline
One suggestion (which may be a non-event): Make sure you can switch your channel dipswitches easily. I've been to two off-seasons that've done it this way (Mission Mayhem and Cal Games), and teams who can't access them just hold up the process.
(Same with the team numbers--you'll have to change the MSB to get some channels.)
Unread 31-10-2006, 20:53
DanDon's Avatar
DanDon DanDon is offline
ohhh MY god
AKA: Dan Hoizner
FRC #0375 (The Robotic Plague)
DanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond repute
Send a message via ICQ to DanDon Send a message via AIM to DanDon Send a message via MSN to DanDon
We have that covered. The OI is probably going to be on a hinged screen, that way all ports and switches are easily accessible.
Thanks for all the suggestions, and keep 'em coming.
Unread 31-10-2006, 21:09
eshteyn's Avatar
I have gotten a 7 inch screen and we will get a laptop, stick the insides into the control board and have a built in dashboard viewer
Unread 31-10-2006, 21:16
eshteyn's Avatar
that is the screen I'm going to use in the control board to make a built in dashboard viewer
Unread 31-10-2006, 21:23
Jeremytice's Avatar
Jeremytice Jeremytice is offline
Addicted to FIRST!
FRC #1126 (SparX)
Jeremytice is a name known to allJeremytice is a name known to allJeremytice is a name known to allJeremytice is a name known to allJeremytice is a name known to allJeremytice is a name known to all
Send a message via AIM to Jeremytice
Sweet Controller station! I would add some decals for your team number or paint it your teams colors. Awsome job, its very neat and looks really good. I like the screen thats going to go into it.
2006 SparX FLR champions with 229 and 1567 after being seeded 1st and Radio shack innovation in controls at FLR
2006 Galileo Division-DIVISION CHAMPION (thanks to 177 and 201)
2006 BattleCry great alliance 1519 and 195.
2006 RCCR hometown champs with 378 and 2567
2007 FLR Innovation in Contols award
2007 Buckeye General Motors Industrial Design Award
2007 Buckeye Finalist with 1038 and 1528
2007 Galileo quarterfinalists with 229 and 191
2008 FLR finalists with 378 and 1551
2008 Buckeye Champs with 1024, 1386, and 2048
2008 Buckeye Motorola Quality Award
2008 IRI Finalists with 1024 , 1625, and 1731
Unread 31-10-2006, 22:12
eshteyn's Avatar
Does anyone else have any suggestions of what we should put on this control panel?
Unread 31-10-2006, 22:20
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
FRC #5507 (Robotic Eagles)
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
There looks like a really nice spot on the right for an easy button.
Unread 31-10-2006, 22:37
eshteyn's Avatar
Unfortunately I'm putting so much stuff into this board that i cant fit anything into it
Brand New Aces High Logo RIgnazio Computer Graphics 11 03-02-2006 21:25
pic: Custom Built Stopwatch Kyle Fenton Extra Discussion 18 18-12-2004 20:57
Custom Control Box D.Viddy Programming 3 15-02-2003 11:35
RAMBOTS, brand new webpage. archiver 2000 0 23-06-2002 23:06
