Go to Post I think a lifetime of learning properly and then teaching others and inspiring the youth is more important to myself at least than being on the news for a couple seconds during a voice over. - Elgin Clock [more]
Thread Tools Rating: Thread Rating: 15 votes, 5.00 average. Display Modes
Unread 02-11-2006, 22:23
Jno
FRC #0610 (Crescent Robotics)
Re: pic: Team 610 Off-Season Tank Drive Prototype
How are you going to drive the belts off of the drive wheels?
Why not move the transmissions to the back in order to give more pushing power if pushing from that side?
How are your going to run a chain from the transmission when the sprocket seems to be mounted below the drive wheel?, the tranny housing will be in the way.
Wow thanks for all the questions. So to drive the belts there is going to be #35 chain from the gearbox's to the rear sprockets (you can see one in the back left corner). The reason the gearbox's are place in the center and not in the rear is because of the HUGE importance of keeping the center-of-gravity over the center idlers in a tank drive system. In my discussions with 1114 they couldn't stress this point enough to me, how important it is to have the CoG centered. The sprocket is mounted directly on the rear axle, the drive wheel (pulley in this case) is 4" diameter and there is plenty of clearance for the transmitions.
Why is the frame so "skimpy" for a tank like that?, if you want a powerful drive train build a frame to take a lot of beatings
the reason this design is so "skimpy" is because of our experiences last year and having to drill thousands of holes in out robot you can say we are a little weight conscience . Also, this is a prototype, it is designed to be simple and prove the concept. In an age with bumpers there is no need to have 1/2" aluminum walls for your robot to survive a season, but yes for a FIRST robot we would beef it up a bit. As well we were only able to find 1/4" thick 3" square aluminum, where this CAD is 1/8" thick. So the real thing will be beefier that this CAD makes it look.
We are actually planning on testing two different spring tensioner system. The first one is on there, if you look closely at the top of the tracks you can see an area cut out where we have a tensioner pushing up on the bottom of the track. Also, we are planning on testing the traditional spring tensioner pushing on one of the wheels to tension it.
I like the use of sheet metal, it looks like a nice cheap way to build a strong frame. It looks like you may want some diagonal braces in there though, it doesn't appear to have too much to prevent it from getting knocked out of square. I might be missing something, though. I look forward to seeing how it turns out, looks like fun!
We just bought a new break/shear system which we will be using for the first time on this robot. We have heard a lot of great things about working with sheet metal, it will be interesting to see how this build goes for us.
thanks for all the questions, keep them coming,
Jonathan Norris
Co-Founder of Taplytics.com
pic: 213 - Drive prototype teaser Tyler M. Robot Showcase 10 07-01-2007 20:56
Extreme Off-Season Events by Team 759 Rich Wong Off-Season Events 3 04-05-2005 07:02
pic: Team 610-Teaser Type Thingey n_0163 Robot Showcase 9 02-02-2005 14:13
pic: 226 Off-Season Prototype Chassis Matt Reiland Robot Showcase 2 01-02-2005 19:33
pic: TEAM 610 ROBOT CD47-Bot Robot Showcase 13 29-03-2003 21:40
