Go to Post The game is as much a competition of strategies as it is of robots. There is never any one "best strategy." If teams choose to use this as their strategy, find one that will beat them. - srjjs [more]
Unread 08-11-2006, 21:58
REVving up for a new season
FRC #2848 (All-sparks)
Re: pic: Completed Mecanum Module
Originally Posted by M. Krass
I'll look to see if we have some of that lying around somewhere as well. Thanks for the suggestion.
We'd been planning on using the same system of retaining the pinions as on the kit transmissions. The team is a bit averse to using Loctite on anything because of the large amount of plastic we typically have on the machine. Instead, we use lock nuts.
What we did last year for holding the pinions on was file a small grove in the motor shaft and use an e-clip. Since you have a key way, and a setscrew it doesn't take much to hold the pinion on the motor shaft. The trick with this is to cut the grove to match a size of eclip.
Greg Needel│www.robogreg.com
pic: Mecanum Wheel Module Gearbox Madison Technical Discussion 22 05-03-2007 01:05
pic: Team 637 Completed! Noah Melamed Robot Showcase 3 18-03-2005 18:58
pic: 494 Completed Robot want2modmygt Robot Showcase 9 27-02-2005 00:17
pic: 195 Completed Robot Tom Bottiglieri Robot Showcase 11 20-02-2005 23:22
pic: ROBOT COMPLETED CD47-Bot Robot Showcase 1 25-02-2003 13:32
