Go to Post FIRST builds bridges, and absolutely should not build walls. - Jacob Bendicksen [more]
Unread 12-11-2006, 07:09
Aren_Hill's Avatar
Build Nifty Things
pic: frame for monster
A guy who likes robots.
Unread 12-11-2006, 07:12
crazykid234's Avatar
crazykid234 crazykid234 is offline
Techincal assist
AKA: Brian Clegg
FRC #1646 (Precision Guessworks), Alumni FRC #234 (Cyber Blue)
crazykid234 is a splendid one to beholdcrazykid234 is a splendid one to beholdcrazykid234 is a splendid one to beholdcrazykid234 is a splendid one to beholdcrazykid234 is a splendid one to beholdcrazykid234 is a splendid one to beholdcrazykid234 is a splendid one to beholdcrazykid234 is a splendid one to behold
Re: pic: frame for monster
could this be the start of a monster crab drive? (magic 8 ball says yes). Seriously though, what are the little cut-outs at the bottom of the frame for? Kudos for getting started before the season!
Don't see the world as it is and ask why; see the world as it could be and ask, why not? - unknown author
Unread 12-11-2006, 09:37
Kim Masi's Avatar
Kim Masi Kim Masi is offline
125 Member, cause Brando says so :p
FRC #0125 (NUTRONS)
Kim Masi has a reputation beyond reputeKim Masi has a reputation beyond reputeKim Masi has a reputation beyond reputeKim Masi has a reputation beyond reputeKim Masi has a reputation beyond reputeKim Masi has a reputation beyond reputeKim Masi has a reputation beyond reputeKim Masi has a reputation beyond reputeKim Masi has a reputation beyond reputeKim Masi has a reputation beyond reputeKim Masi has a reputation beyond repute
Send a message via AIM to Kim Masi
Wow, that is a lot of box aluminum...looks like it could be very heavy
Bobcat Robotics-Team 177: 2004-2007
The NUTRONS-Team 125: 2008-2009, 2011-2012ish
Unread 12-11-2006, 11:01
Jack Jones Jack Jones is offline
Retired
Jack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond repute
To relieve the pressure (hot gasses) from inside the square tube. Otherwise, the molten weld would blow out.
Unread 12-11-2006, 12:07
Kellen Hill's Avatar
Kellen Hill Kellen Hill is offline
Strategist
AKA: The user formerly known as 'hill'
FRC #1746 (OTTO)
Kellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond repute
The frame is actually about 16 pounds. Our team is having a little comettion between two groups with two drivetrains to see which one works better.
1625 Winnovation Member: 2005-07
1625 College Mentor: 2007-11
525 Swartdogs Mentor: 2011-12
1746 OTTO Lead Mentor: 2013-Present
Unread 12-11-2006, 12:19
Dan Richardson's Avatar
Dan Richardson Dan Richardson is offline
iR3 Creative
AKA: Dan Richardson
Dan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond repute
16 LBS! what thickness did you use!? Also you can typiaclly use drill holes for the relief don't need large cut outs ( just for next time ) Looks good tho, I've always loved the strength that these kind of frames give, especially with the extra confidence if you ram someone or something that it most likely won't fall apart. Looks good.
CO-Founder of Robot in 3 Days and the Robot in 3 Day Challenge.
Unread 12-11-2006, 12:41
Alex Golec Alex Golec is offline
FRC Advocate
no team (FiM Volunteer)
Alex Golec has a reputation beyond reputeAlex Golec has a reputation beyond reputeAlex Golec has a reputation beyond reputeAlex Golec has a reputation beyond reputeAlex Golec has a reputation beyond reputeAlex Golec has a reputation beyond reputeAlex Golec has a reputation beyond reputeAlex Golec has a reputation beyond reputeAlex Golec has a reputation beyond reputeAlex Golec has a reputation beyond reputeAlex Golec has a reputation beyond repute
I would agree with that, but it also appears that all of the cutouts are centered in each of the wheel chambers - perhaps this will be a mounting point for the lower bearings for each wheel assembly.
16 pounds, eh? Thats not too bad. And with bumpers, it looks like that frame will be able to take quite a beating.
_Alex
Unread 12-11-2006, 13:10
Aren_Hill's Avatar
Build Nifty Things
this frame is constructed out of 1x1x1/8th and 1x1x1/16th inch tubing
and the holes are for mounting some things not for gas since the endes of most tubes are with open or have a little slit left after welding. I designed all of this in inventor and we still have some interesting parts to put on such as some
dewalt threes speeds yes yes
edit: and yes its for a crab drive
Unread 12-11-2006, 13:16
CraigHickman
I'm guessing by the frame style, you guys are gonna have a 3 speed coaxial crab. Kudo's on going for it, and I'd love to see tons of pictures/movies, as I am designing one of my own.
Unread 12-11-2006, 13:21
FRC Advocate
3-speed crab? You definitely have my attention. Will the transmissions be mounted within the wheel module or will they remain stationary with a rotating connection (e.g. bevel/miter gears) to transfer the power?
Unread 12-11-2006, 13:24
Aren_Hill's Avatar
Build Nifty Things
its coaxial with cim and dewalt mounted vertically beside the module and getting to the wheel through some sprockets and miter gears
the three speed should give us 3fps, 7fps and 12fps
this frame will end up weighing about what our previous 2 years have (which i haven't been on that build team) but with a 3speed swerve
Unread 12-11-2006, 13:26
Dave Scheck's Avatar
Dave Scheck Dave Scheck is offline
FRC #0111 (WildStang)
Dave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond repute
That frame looks very familiar...
http://www.wildstang.org/gallery2/v/...t_004.jpg.html
http://www.wildstang.org/gallery2/v/...60143.jpg.html
Unread 12-11-2006, 13:27
Aren_Hill's Avatar
Build Nifty Things
i must admit dave i've had some good inspiration
my favorite bot of your guys was 2003
and these guys have been of some inspiration
http://www.chiefdelphi.com/media/photos/25328
and http://www.chiefdelphi.com/media/photos/25244
or just search cdmedia for crab or swerve and i've looked at all of those
Unread 12-11-2006, 16:32
colin340 colin340 is offline
human
AKA: Colin Nobles
FRC #0148
colin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond repute
or maybe balldrive
61 77 77 20 77 69 74 74 6c 65 20 62 61 62 79 20 63 6f 6e 64 6f 72 20 69 73 20 72 65 61 64 69 6e 67 20 43 44
Unread 12-11-2006, 18:29
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
RyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond repute
The only problem with building and welding a frame together right now is that we have really no idea what the game is going to be. They may want a wide robot or a long robot. That's what happened to us last year, we had a built frame before the building season, but after we saw the game, we wanted a wide robot. Just keep this in mind. Right now we have a frame built, but not welded. Also our design makes it easy to change it from long to wide.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
pic: SOAP 108 - 2006 8 CD Burning Monster (1 of 3) Matt Keller Extra Discussion 3 02-03-2008 17:08
pic: It's a Monster for sure - Team 968's practice robot Travis Covington Robot Showcase 14 22-03-2006 03:01
alternate construction for frame work mechanicalbrain Technical Discussion 5 24-04-2005 19:38
pic: Team 237's completed Monster Scott Shaw 237 Robot Showcase 12 28-02-2005 19:27
pic: The LocTite Monster CD47-Bot Extra Discussion 7 28-02-2004 15:30
