Go to Post Fame is a funny thing, you can do nothing and get it, and do everything and get none. For me, it's not fame, but infamy that follows me. - Joe Matt [more]
Unread 12-11-2006, 12:27
TheOtherGuy's Avatar
Unregistered User
AKA: Kevin Forbes
FRC #4183 (Bit Buckets)
pic: 2nd mecanum prototype
Unread 12-11-2006, 12:28
MrForbes MrForbes is offline
Re: pic: 2nd mecanum prototype
It's a neat wheel, pretty easy to make the rollers and side plates, but they are traction impaired...any ideas how to get some gription on it? or alternate materials that would work in place of wood, be sort of easy to get hold of, and easily machinable?
Unread 12-11-2006, 12:31
Alex Cormier's Avatar
www.TwoPencilDesigns.com
FRC #1405
you ever see that red grip stuff that you can dip your tools into? im sure it would work great!
Unread 12-11-2006, 12:59
efoote868 efoote868 is offline
foote stepped in
AKA: E. Foote
FRC #0868
efoote868 has a reputation beyond reputeefoote868 has a reputation beyond reputeefoote868 has a reputation beyond reputeefoote868 has a reputation beyond reputeefoote868 has a reputation beyond reputeefoote868 has a reputation beyond reputeefoote868 has a reputation beyond reputeefoote868 has a reputation beyond reputeefoote868 has a reputation beyond reputeefoote868 has a reputation beyond reputeefoote868 has a reputation beyond repute
868 molded ours with a rubber compound.
first we milled out the mold from aluminum (which is probably the hardest part of the operation)
then we got a 2 part rubber mixture, mixed it, and poured it in (we used one of smooth on's products)
last we put it in a toaster oven to speed the reaction up, then popped the rollers out after 30-60 mins.
Very easy to make (once you had the molds), and easy to mass produce.
Good Luck!
Be Healthy. Never Stop Learning. Say It Like It Is. Own It.
Like our values? Flexware Innovation is looking for Automation Engineers. Check us out!
Unread 12-11-2006, 14:18
dbell dbell is offline
Mentor for team#3937 (Breakaway!)
AKA: David Bell
FRC #1519 (Mechanical Mayhem)
dbell is a splendid one to beholddbell is a splendid one to beholddbell is a splendid one to beholddbell is a splendid one to beholddbell is a splendid one to beholddbell is a splendid one to beholddbell is a splendid one to beholddbell is a splendid one to behold
I know of one team that made their Mecanum rollers out of polyurethane. These were not as grippy as rubber, but that would probably be better than wood.
How did you make the metal plates that hold the wheels so accurately and precisely?
Unread 12-11-2006, 14:45
Steve used a hand held drill and tin snips and pliers to make the plates.
Unread 12-11-2006, 22:54
Stuart's Avatar
Stuart Stuart is offline
#include coffee.h
FRC #1745 (P51- Mustangs)
Stuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond repute
Send a message via AIM to Stuart
you guys do BEST?
Proud mentor of Team #1745 the P-51 Mustangs
If at first it doesn't work, use a hammer.
If that doesn't work, use a bigger hammer.
Unread 12-11-2006, 23:08
nope never heard of it till now....
http://www.bestinc.org/MVC/About/history
this is what you're talking about, I assume?
Unread 12-11-2006, 23:21
Nitroxextreme's Avatar
Nitroxextreme Nitroxextreme is offline
Relation to Mrs. Steve
AKA: Jon
FRC #1626 (Falcon Robotics ; 190 (Gompei and The Herd))
Nitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to behold
Send a message via AIM to Nitroxextreme
Be very careful with the wooden rollers. Unless you have a precise way of making them (lathe)...they will not come out as planned.
I used a sloped wooden cylinders back when I was in 7/8 grade on a Junior Solar Sprints Cars.("Freak on a Leash" and "Frank the Tank") Some sort of CVT...but ultra simplified with only acceleration. Tried to do sandpaper on drills just didnt work out the way planned. So contacted the local high school shop teacher and he helped me out with lathe. He also was the first person to introduce me to FIRST and got me hooked.
"He needed a chuck norris lesson in FIRST"...."I will give him a round house kick to the face...with gracious professionalism"
Unread 12-11-2006, 23:51
thanks for the advice...I have a (very old and worn out) lathe, but even so it takes a while to figure out how to set everything up right so the rollers come out right, concentric with the center hole, etc.
pic: Completed Mecanum Module Madison Technical Discussion 9 12-11-2006 19:39
pic: 1" mecanum Tytus Gerrish Extra Discussion 8 04-10-2005 13:44
pic: Micro Mecanum wheel Tytus Gerrish Extra Discussion 6 12-05-2005 23:20
