Go to Post Our safety manager isn't allowed to use the power tools, because he used a drill as a pointing device. - daniel_dsouza [more]
Unread 15-11-2006, 11:54
Gabe's Avatar
Gabe Gabe is offline
Pocket Full of Tools
FRC #0604 (Quixilver)
Gabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond repute
Re: pic: Colson Wheel and Sporcket.
1. A paint can opener has a hooked end, so I sharpened this on a grinding wheel until the edge was like a chisel (think of a paint scraper). Then I mounted the wheel on a bolt and spun it in a drill press and, using the sharpened scraper, started shaving away.
2. For the bolt holes I went online and printed a full size drawing of the kit sprocket, which I glued to the aluminum to show me where I had to cut and file, including where to drill the bolt hole. I used the same method to align the bolt holes on the wheel.
[EDIT]Sorry, Billfred. Misread your first question, but Greg answered it below.[/EDIT]
Team site: Q U I X I L V E R
My favorite tool is my imagination; I’m always finding new ways to use it.
Colson Wheels sanddrag Technical Discussion 11 22-03-2006 10:02
Algorithim question: 4 wheel steering and power Validius Programming 2 15-11-2005 17:41
pic: 885 Right-center wheel and drive assembly CD47-Bot Robot Showcase 2 30-04-2004 18:27
wheel hub kit and sprocket archiver 2001 7 23-06-2002 23:27
