Go to Post FIRST is here to inspire you, to challenge you. Part of that process is giving you a task too hard, resources too little, people too many, time too short. - ebarker [more]
Unread 15-11-2006, 13:56
REVving up for a new season
FRC #2848 (All-sparks)
Re: pic: Colson Wheel and Sporcket.
Originally Posted by Billfred
I'm looking at the wheel, and I'm wondering two things:
1) What exactly got shaved off with the paint can opener?
The colson wheels have a round sidewall, i suspedct the used the scraper like a lathe and flattened out the side wall.
Originally Posted by GABE
2. For the bolt holes I went online and printed a full size drawing of the kit sprocket, which I glued to the aluminum to show me where I had to cut and file, including where to drill the bolt hole. I used the same method to align the bolt holes on the wheel.
I have used this method before to drill holes, I just would like to issue a warning to people considering doing this. You need to make sure you have a center mark on the holes, then center punch them. Using just the exterior of the hole to line them up can cause issues with proper spacing. Otherwise this is a good solution/use of cad for teams without CNC or machine tools to build parts, It works especially well for sheet metal whole locations and anything that has a flat surface. It can also be used to make cut lines on parts.
I have used colson wheels before for other applications and they are very durable, but the major advantage comes from the weight and price of these wheels, the tread is 65A durometer, similar to the wheel chair wheels.
Greg Needel│www.robogreg.com
Colson Wheels sanddrag Technical Discussion 11 22-03-2006 10:02
Algorithim question: 4 wheel steering and power Validius Programming 2 15-11-2005 17:41
pic: 885 Right-center wheel and drive assembly CD47-Bot Robot Showcase 2 30-04-2004 18:27
wheel hub kit and sprocket archiver 2001 7 23-06-2002 23:27
