Re: pic: 3rd mecanum prototype
so, Kevin, how do these wheels work?
here's the video
http://www.selectric.org/nerds/robot...xmecanum01.wmv maybe Kevin could describe what's going on here? |
Umm... well, lets see. It's definitely not working correctly! (probably because the front two wheels have their rollers set at 10-15* less than the other two)
For those of you too lazy to watch the movie (which is only about 30 sec by the way), all 4 wheels are mounted on a simple robot and the holonomic code was downloaded to the microcontroller. It runs just peachy in tank drive mode, but once you start trying to strafe or move in any other direction, it moves in strange and mysterious ways (again, probably due to the lack of accuracy when mounting the rollers on the front 2 wheels). Also, the shiny-slick tiles don't help either... |
It may help to give it a suspension; from what I've seen on here they are almost essential for mecanum drive trains. Just build two halves of the robot and connect them on a metal shaft, might help it keep it's wheels on the ground. Also, try to make all of the wheels the right shape if you can.
| pic: 2nd mecanum prototype | TheOtherGuy | Extra Discussion | 9 | 12-11-2006 23:51 |
| pic: Completed Mecanum Module | Madison | Technical Discussion | 9 | 12-11-2006 19:39 |
| pic: Aiming High (at 1/3rd scale) | Tim Arnold | Extra Discussion | 6 | 23-04-2006 13:23 |
| pic: 3rd day of build season. | Arefin Bari | Extra Discussion | 9 | 20-01-2006 23:21 |
| pic: 1" mecanum | Tytus Gerrish | Extra Discussion | 8 | 04-10-2005 13:44 |
