Go to Post Maybe the lesson the internet is trying to teach us is to "Think before you post, the machine is watching and never forgets..." - IKE [more]
Unread 22-11-2006, 00:25
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: pic: Team XBot Mecanum Practice Chassis
Originally Posted by Kingofl337
If you want to be able to rotate the base has to be square. Your current base will not rotate well when you load another 100lb on it.
The required torque to get a Mecanum wheel to move sideways certainly increases with additional weight. I think that can be addressed somewhat by making the rollers spin a little freer.
Why do you think squareness is an issue? The center of mass should probably be as close as practical to the center of the 'bot in order to keep weight equalized on all the wheels, but I think a long or wide rectangle ought to work fine.
pic: Xbot vs. Cheesy Poofs, Round 2. Madison Robot Showcase 16 27-10-2006 00:18
pic: Practice Mecanum Chassis Madison Extra Discussion 39 10-09-2006 20:17
pic: FRC 488 - XBot - Hex Madison Robot Showcase 5 21-02-2006 19:30
pic: Team 27 2004 Chassis CD47-Bot Robot Showcase 2 25-02-2004 23:29
pic: Team 369 Chassis CD47-Bot Robot Showcase 7 11-02-2004 19:58
