Thread Tools |
Rating:
Display Modes |
Re: pic: Team 948 2-Speed Ball-Shifting Gearbox CAD Drawing
I never would have thought of having a 2-speed for shooting. That is very creative!!! Great job on the inventor there! I am new to inventor myself... learning quite quickly... hopefully I can something that kool one day haha. But I am very impressed!!!
This looks good. Keep up the good work.
I have to agree with the weight issue. Also once you have the hubs off you could put them a lot closer together making the box thiner. I do not think there is more friction on ball bearing shifters than there is on a dog shifter. Also a ball bearing shifter can be made oil filled inside the shaft. I also designed a Ball Bearing Shifter that is currently being manufactured. Once is done I will post pics along with a white paper. Thanks to Team 222 for the idea. |
Who said this was for the shooter? ![]() |
Be wary, you must machine everything perfectly, otherwise it will shred itself. 114 built one of these last year, and had far too much fun with it, until we realized we had no weight for the pneumatics. However, during the offseason, this is a great shifting system. I encourage you to keep playing with the design.
Another tip is on the shifting plunger, you may want to mount springs on the part that forces the balls out, to reduce wear on the part. This is due to the fact that it needs to be able to lag until the balls line up with the grooves in the gear. Good luck, and I highly reccomend this type of drive system! |
I was looking at the Inventor files and it shows the shaft that is connected to the piston and the piece that pushes the bearings as two separate pieces. However it shows that the shaft that goes to the piston has a recessed and the piece that pushes the bearings has an ID equal to the diameter of the recessed. I hope that is understandable.
Anyway my question is how are you going to insert one in the other? |
| Team 33's 2004 gearbox CAD files | AdamHeard | Inventor | 1 | 03-10-2006 19:07 |
| pic: My First time.....(CAD car drawing) | negfrequency | Extra Discussion | 13 | 26-06-2006 23:12 |
| pic: Team 865 custom 2-speed gearbox | geo | Technical Discussion | 2 | 20-04-2006 18:13 |
| pic: Vex 2-speed gearbox | crazykid234 | Extra Discussion | 3 | 03-01-2006 20:18 |
| pic: 222 2005 ball bearing style shifting transmission | team222badbrad | Robot Showcase | 2 | 11-03-2005 14:17 |
